2018 RDX - warpped rotors?
Old Apr 3, 2026 | 02:09 PM
sampoodle's Avatar
6th Gear
My wife's ow mileage 2018 RDX seems to exhibit warped rotor issue: pulsating when brake applied. Not too bad but annoying.
Is there a known tendency for disks of that model year to develop warping?
Old Apr 3, 2026 | 02:12 PM
samiam_68's Avatar
How many miles on these rotors? I have a 2015 and the original front rotors warped after about 45K miles. The replacement OEM rotors are holding up well so far. Car is nearing 100K miles.
Old Apr 3, 2026 | 02:27 PM
mrgold35's Avatar
mrgold35
The warped rotor feeling has been an issue with a lot Acura vehicles for a few decades. It is narrowed down to uneven distribution of brake pad material on the rotors creating hi/low spot that feel like "warped rotors" when you apply the brakes. You can turn the rotors to even out the hi/low spots; but, it will come back in the same amount of time if you drive the same way. We don't do brake pad embedding process anymore and not sure if that would help reduce the issue with OEM pads/rotors?
The 3 solutions that work for most are:
- change to aftermarket pads (turn rotors to remove old OEM brake pad material first, embedding process would help also)
- change to aftermarket rotors (sometimes OEM pad perform better with less "warping")
- change both aftermarket pads and aftermarket rotors
Old Apr 3, 2026 | 03:05 PM
sampoodle's Avatar
6th Gear
It is my wife's car, I believe mileage is about 50K. That would match your experience.
Good the hear new OEM parts fixed it.
Old Apr 5, 2026 | 04:38 PM
EasyLoveRDX's Avatar
New pads, rotors and slide pins. Fresh brake grease on the slide pins. Bed the new brakes properly with the 30/30/30 method.
Starting fresh is the easiest way to eliminate these issues imo.
Old Apr 6, 2026 | 09:40 AM
dtownfb's Avatar
I bought my 2017 Tech used with 41k miles. Front brakes started warping about 55k miles. My mechanic resurfaced the rotors and put new pads on. He told me there was plenty of meat left on the rotors. I'm at 152k miles now and the brakes are still braking smoothly. The process that EasyLoveRDX wrote is the way to resolve the problem.
axela3
3G RDX Problems & Fixes
14
Jun 9, 2025 07:05 PM
swttsx007
3G RDX (2019+)
19
Mar 13, 2024 09:52 PM
noshow
3G RDX (2019+)
Feb 13, 2023 11:50 AM
lumn8
1G RDX (2007-2012)
Aug 26, 2017 08:28 AM
