2011 RDX Breaks
Stay Out Of the Left Lane
Unless the rotors are badly warped, deeply scored or below minimum thickness, there is no reason to replace them. Rotors can / may need to be turned if they are warped, but you should be good to go after that.
You really don't have to change the rotors unless they are badly messed up.
Change the pads to a ceramic set.....night and day difference way better that the stock ones.
Lots of choosings on the Bay for pad n rotors for under 150 too
