Brake light sockets melting
Old Apr 11, 2019 | 07:40 AM
26Shaun's Avatar
Unhappy Brake light sockets melting
I was changing the brake light bulb in my 2013 RDX the other day and found that the socket had melted so I took off the opposite side and that one was melted as well. These had the original factory bulbs installed and I don't feel like this should have happened. Is it a common thing?
I called the dealer and the sockets alone were about $46 each, but then I took the part number (33302-S5A-A01) and found the same OEM part on Amazon, of all places, for $26 each with 1-day shipping. Needless to say I ordered them from Amazon, along with some Philips Ultinon 7443R LEDs, and installed them the next day. Hopefully the LEDs run a bit cooler than the stock incandescents and the new sockets will hold up better, but only time will tell I guess.
Below is a pic of the perfectly normal turn signal socket at the top and the brake light socket below. The brake light socket showed a little corrosion on the metal but the plastic was brittle to the point where it was beginning to disintegrate.
Old Jul 10, 2019 | 11:27 AM
DFB in KY's Avatar
I have the exact problem on our 2013 RDX but when I ran that part number on Amazon it says it does not fit 2013 RDX. Did it work for you? Thank you.
Old Jul 15, 2019 | 09:34 AM
26Shaun's Avatar
Not sure why Amazon says it doesn't fit, but that is the correct PN as found here. https://www.acurapartswarehouse.com/...2-s5a-a01.html
Old Mar 16, 2026 | 09:50 AM
Leo06's Avatar
4th Gear
Long term?
How did these sockets and LEDs work out?
Old Apr 7, 2026 | 09:57 PM
Sadie.rains's Avatar
3rd Gear
I had the same thing happen in my 2014 RDX. First the drivers side, then about 2 weeks later, the passenger side. Dealership charged me over $150 for two lights over that 2 week period. Since then I have been periodically pulling them out and checking to see if they are melting again. I just assumed maybe it was something related to the system and not a good ground to the frame.
schen72
1G RDX (2007-2012)
15
Aug 7, 2020 11:05 AM
cocoloco72
Mar 29, 2014 06:37 PM
Xxb005txx
Mar 26, 2014 08:19 AM
9632tl
1G TL (1996-1998)
Jan 28, 2011 12:02 PM
