Brake lamp light on
Old Mar 29, 2014 | 10:56 AM
cocoloco72's Avatar
5th Gear
Brake lamp light on
1999 Acura 3.2 TL. The brake lamp light comes on/stays on and the right turn signal freezes when the brake pedal is pressed. The brake lamps are working.
Old Mar 29, 2014 | 12:54 PM
Tosh's Avatar
Eurotrash
Corroded or missing ground wire in one of the rear light assemblies? (just a guess...)
Have you put in any LEDs?
Old Mar 29, 2014 | 01:00 PM
cocoloco72's Avatar
5th Gear
No LEDs
Old Mar 29, 2014 | 01:06 PM
3.2TLc's Avatar
Yeah, check the rear bulb connections and sockets. May be a good time to install some new bulbs and apply some dielectric grease. Also make sure that the 3rd high mount lamp bulbs are all working.
Old Mar 29, 2014 | 01:10 PM
Tosh's Avatar
Eurotrash
In the Helm's service manual for my CL there's a long section showing where and how to diagnose brake light problems. Get your hands on one for the 99 TL and follow it?
Old Mar 29, 2014 | 01:13 PM
cocoloco72's Avatar
5th Gear
I replaced the bulbs but did not use dielectric grease. I'll try that. A guy i work with suggested the sensor behind the brake pedal, what are your thoughts?
Old Mar 29, 2014 | 01:18 PM
Tosh's Avatar
Eurotrash
Doesn't sound like a problem with the brake pedal switch....
Only the right turn signal freezes? Can you describe problem better?
Old Mar 29, 2014 | 01:35 PM
3.2TLc's Avatar
Brake lamp dash light on.....
Does the RHS turn signal work normally when activated......"without pressing the brake pedal" ????
My guess is that the problem may be a wiring issue or bad socket for that affected side. Maybe a bad ground. Check that side for power. Double check the socket and spray electrical cleaner in it. Maybe poor contact ?
Old Mar 29, 2014 | 02:14 PM
cocoloco72's Avatar
5th Gear
The right signal flashes until i press the brake pedal and begins to flash again when you lift off the peda. The brake lamp light comes onthe first time you press the pedal and remains on until you turn off the ignition. I replaced the bulbs when the lamp light first came on even though brake lights were working. This didn't fix the problem. I don't know if the two issues started at the same time.
Old Mar 29, 2014 | 02:17 PM
cocoloco72's Avatar
5th Gear
Also, the car had just been in the shop to have the alternator replaced. These issues started right after I got it back.
Old Mar 29, 2014 | 06:37 PM
3.2TLc's Avatar
More than likely a wiring or socket issue with something shorting out on that side.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
ellisd03tls
Sep 8, 2015 04:17 PM
