P3400
Old Jan 23, 2020 | 05:48 PM
Jeckz's Avatar
P3400
So I got a p3400 code on my 13 RDX. I know it’s the oil pressure sensor for the cylinder shut off.... my question is because there’s some confusion from the research I’ve done.... is that the sensor by the firewall or by the dipstick?
Old Jan 23, 2020 | 06:45 PM
EE4Life's Avatar
Forum Contributor
See TSB 13-015 - MIL Comes On With DTC P3400 and/or P3497 in the 2013 TSB thread.
https://acurazine.com/forums/second-...letins-950914/
Old Jan 23, 2020 | 08:30 PM
Jeckz's Avatar
Thanks!
Old Apr 4, 2024 | 02:12 PM
VisualEchos's Avatar
Andrew
Got this code on my '15 RDX the other day after leaving a gas station. The dash center said "check emission system", but my code reader showed "P3400 cylinder deactivation system bank 1". After clearing it the code came right back within a few miles. After the second clearing it hasn't returned.
Car was full of oil.
I called Honda and they said it was decently common. My car has 147K on the clock. They said they replace both oil pressure sensors and o-rings, so I ordered them off of Amazon for a big bad $62 and will replace them this weekend.
Old Apr 4, 2024 | 03:10 PM
Just curious, can you provide the Amazon link for the sensors ordered?
Old Apr 5, 2024 | 06:46 AM
Andrew
Of course.
You'll need to buy 2 switches and 2 o-rings, they are identical front to back. And if you don't have a 24mm deep-well socket you'll need one of those as well.
Switch: P/N: 37240-R70-A04
O-Ring: P/N: 91319-PAA-A01
Switch link:
Amazon Amazon
O-Ring link:
Amazon Amazon
For whatever reason, Amazon says that it doesn't work for the '15 RDX, but it does, as it's the same part number for all years 13-18.
Old Apr 30, 2024 | 03:05 PM
druss44's Avatar
Of course.
Switch link:
Amazon Amazon
O-Ring link:
Amazon Amazon
When you replaced both did the engine light turn off?
mayjarjar
Jan 14, 2019 06:12 PM
JBSTRD
Oct 28, 2017 08:56 AM
rvmeush
Mar 12, 2008 10:20 PM
92GSR
1G TSX Problems & Fixes
Sep 11, 2003 01:59 PM
