Intermittent Power Socket (Cigarettes Lighter) Failure
Old Nov 20, 2021 | 08:46 PM
chilly731's Avatar
Hello all.
Wondering if anyone has had this issue in their 2016-2018 RDX: recently my front power socket failed. I've changed the fuse (fuse slot #27) - I'm guessing the old one was shot (looked burnt at the part that is meant to break). Also replaced the center console one (fuse slot #12), after long delay (died long time ago). Both 20 amp fuses, per instructions.
The center console socket works great. The front one, however, worked for a few hours, then stopped after I stopped to fill up with gas. I tried taking it out to see if it's a connection issue, but the position is too awkward to reach the disconnection tabs. Tried wiggling it, to no avail. Yesterday, i randomly plugged in my dash cam, it worked. Today, the socket worked for 40 minutes, flickered for a bit when i needed to disconnect and connect the dashcam (it was frozen), and then stopped again fully. Wiggling didn't help, neither did lightly slapping the housing to see if it would at least flicker.
Just a full disconnect like last time. The fuse was swapped for testing, so it is not the issue.
Any ideas? Thanks in advance.
Cool Runnings
Jan 24, 2020 03:23 PM
DebKenn
2G RDX Problems & Fixes
Sep 7, 2017 04:59 PM
FrankieN
1G TSX Problems & Fixes
Sep 6, 2011 03:35 PM
VieTLover
Jul 7, 2011 08:16 PM
notbond007
1G RDX Problems & Fixes
Feb 11, 2011 01:51 AM
