Start and Stop Button (Won't function)
Old Jul 18, 2021 | 10:53 AM
Radamés León's Avatar
The start and stop button only turns on the panel but not the engine. I already change it and the problem remains
Old Jul 18, 2021 | 11:27 AM
more information is needed.
the engine won't turn over?
is there a clicking noise from the starter?
is there enough juice in the battery?
Old Jul 18, 2021 | 02:23 PM
Rdx 2017
Yes to the 2 las questions. I connect a direct cable from the battery to the starter and turns on. I would like to see the diagram from the buttom to the starter to know which are the relays
Old Jul 25, 2021 | 05:05 PM
egads's Avatar
I would start with the switches on the brake pedal. It is acting just like it would if you did not have your foot on the brake.
Old Jul 27, 2021 | 01:32 PM
dtownfb's Avatar
egads: Would a low battery in the key fob cause this?
Old Jul 27, 2021 | 06:29 PM
egads's Avatar
I'm sure a low key fob battery will show up as a warning, usually before it is completely dead. (Make sure the replacement is a name brand good quality)
The battery under the hood of these things rarely lasts three years for many. Because the whole thing is so electronic,
all hell can break loose with a weak one. The only way to test a battery health is by having a load test done. We had that with dealer service and less than 3 weeks
Later, the battery was dead, so even that is just a snapshot.
If you get in one of these push to start cars and press the start button without your foot on the brake, it will go into acc first and "on" with the second
push. That is what you would do to roll up the windows without starting for instance. Without a key fob (like a dead battery in one) nothing happens.
I think you can start with a dead key fob battery by pressing the fob against start button.
Ifyou have a used Acura you can access a pdf of the owner's manual at:
https://owners.acura.com
Old Nov 21, 2021 | 07:43 PM
Skidoor's Avatar
FWIW I recently had my battery tested by my mechanic, and wanted to see the tester and ask him about it. He told me the tester just measures the internal resistance of the battery. You have to enter the CCA rating into it first. The reading gives an indication of how sulphated the battery has become.
alex corbit
ILX
Oct 18, 2017 07:00 PM
SkC13
Feb 23, 2015 08:37 AM
**WhItE-aNgEl**
Apr 18, 2010 11:33 PM
wingwing
Aug 6, 2007 07:52 PM
Bxscig
Mar 29, 2005 03:43 PM
