Which fuse is for dash 12V accessory socket?
Old Feb 10, 2011 | 09:46 PM
notbond007's Avatar
4th Gear
2007 Acura RDX - front 12v accessory socket not working, but the socket in the console compartment is working. The front one was working and stopped working while air compressor was plugged in. I think the fuse blew. I checked the fuse box diagrams and I do not see a fuse for the front accessory socket. The only fuse I see listed in the diagram is for the one in the console. which fuse number is the correct one for the front (dash) 12V accessory socket?
Old Feb 11, 2011 | 12:01 AM
737 Jock's Avatar
haole kama'a-ina
The front accessory power socket is fuse 29 (15 A) in the under-dash box.
Also, the console power socket is fuse 28 (15 A). If you don't have a fuse, you could try this one to see if power is restored.
Old Feb 11, 2011 | 12:17 AM
notbond007's Avatar
4th Gear
So +B ACC means it is the front accessory socket?
Old Feb 11, 2011 | 12:52 AM
737 Jock's Avatar
haole kama'a-ina
I got that info from the Service Manual, under-dash fuse/relay chart. Fuse 29 is third row up from bottom, seventh position across to the right. Where are you seeing +B ACC?
Old Feb 11, 2011 | 12:55 AM
notbond007's Avatar
4th Gear
Page 401 of the user's manual that lays out the fuse locations.
https://techinfo.honda.com/rjanisis/...707O00397A.PDF
Old Feb 11, 2011 | 01:04 AM
737 Jock's Avatar
haole kama'a-ina
Yes, that is the same fuse.
Old Feb 11, 2011 | 01:51 AM
notbond007's Avatar
4th Gear
Cool. Thanks buddy. My wife will be happy to have it working again.
tsx_boy
Dec 13, 2019 08:33 PM
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
AJRozsa
Oct 5, 2015 07:50 PM
