2017 Acura Transmission slipping
Old Mar 10, 2023 | 11:38 PM
wifesRDXtech's Avatar
Just bought this Tuesday a 2017 RDX tech awd certified pre owned from Acura dealer . 67 K miles .
today when shifting from 2 to 3 the while accelerating ( in auto ) something slipped the rpm’s dropped from 2500 to 1500 , Felt like the tranny was gonna blow up . Jerked the car.
there is a warranty from the dealer I assume they going to address this as per TSB to reprogram software and do the 3 x tranny fluid change .
anything else I should know when I bring it to the dealer tomorrow?
I am really concerned and have no faith this will get fixed from the TSBs
*** I have a video of the speedo and tach while it’s happening just don’t know how to post it here it’s 35 MB *****
Old Mar 11, 2023 | 12:02 AM
Alex Medeiros's Avatar
alexmed2002
Sounds like the Variable Cylinder Management (VCM) playing a part along with the typical RDX jerk in the torque converter of the transmission. It's very common and your transmission shouldn't be slipping already, but doing the TSB and drain/refill 3 times should make a big difference.
Old Mar 11, 2023 | 05:31 AM
jimbo1763's Avatar
I have the same car, except not AWD. Mine will on occasion simply pause during acceleration. It lasts for a couple of seconds, and then the throttle is responsive again. Mine seems to be in the shift between 1-2 as nearly as I can tell.
I have spent a lot of time with the Acura dealer trying to get it fixed, because it's really troublesome. The problem has been that it doesn't throw a code and no one (myself included) can make it bark on command to replicate the issue. It's very sporadic.
I have had the transmission reset and had the three changes of the fluid done, along with the software update that the service bulletin talks about. That may have helped--I really can't tell. It still hiccups, but maybe only once a month. I just have to be careful in timing my merging into traffic. I think it's an electronic issue, but until it throws a code, no one will find it.
Old Mar 11, 2023 | 05:58 AM
jimbo1763's Avatar
Sorry--mine is a 2018, not a 2017. I wanted to correct my error.
Cheers.
Old Mar 11, 2023 | 08:01 AM
Have appointment with dealer this week , will update .
Old Mar 14, 2023 | 04:26 PM
TLinGB's Avatar
Question Drain, measure, replace?
A 3 time drain/refill? On my Gen 7 Accord I could see this, but from what I read about the ZF tranny, you have to be a magician to enter maint mode / drain / fill while engine running and watching for fluid in the view port. What am I missing?
Along those lines, I have seen a reference to simply draining the fluid on the 9 spd ZF, measuring what came out, and putting the same amount of new stuff in. Sounds MUCH simpler. What is the consensus?
Old Mar 15, 2023 | 03:17 PM
RDX is at Acura dealer today , the found a clutch pressure switch throwing a code so they will change that along with doing the Service Bulletin requiring ATF 10 quart fluid change out and software reprogram . Hopefully that solves it , will update down the road .
** on a side note they gave me a 2022 RDX A Spec for a loaner , I can see myself getting a speeding ticket with this thing , lol **
Old Mar 15, 2023 | 03:20 PM
jimbo1763's Avatar
Glad yours threw a code. The way auto repair goes these days, if it doesn't throw a code, they don't know what to do.
Old Mar 21, 2023 | 10:45 PM
Falconee's Avatar
Another bad 3rd gear clutch pressure switch.. I changed mine in the fall and the car (2017)has less than 50k kms on it. It has to be a bad batch or something! Btw its super easy to do if you are mechanically inclined!
Old Mar 24, 2023 | 07:05 AM
** UPDATE no issues since the 3 x auto fluid change , reprogram and pressure switch change ** shifting feels much much better
DubmyRUCA
Feb 15, 2011 05:56 PM
2003blacktl
Oct 26, 2008 02:37 AM
havieri23
Jun 6, 2007 09:15 AM
Control
May 25, 2002 07:39 AM
myrolex
May 17, 2002 08:49 AM
