Transmission Problem ???
I have a 2015 RDX with 191k on it. It's been flawless. As of late, I'm getting shifting issues, 2nd to 3rd....3rd to second. Upshifting can feel like a slip, (the revs jump a bit), then into 3rd. Downshifting from 3rd to 2nd can produce a clunk / jolt feel. Both of these don't happen all the time....maybe 3 out of 10 times. I had the routine trans flush, (this was the 4th), so I take care of it. Question is, is this the beginning of the end? The car's in perfect shape otherwise. No rust or dents, recent brakes and suspension, etc..... A new or re-man trans would be a few thousand, I'm told. thanks.........any input or feedback.
alexmed2002
Hello Alex......you're correct. It wasn't a flush, it was the standard dealer performed trans fluid replacement. Nevertheless, is it time to sell it? I'd rather not, but I don't want it to completely fail. Thanks.
Sounds like it's just the 3rd gear pressure switch(es?). There's 6 switches total on this car, but I never narrowed down exactly which switches control which gears. I think maybe in the past I had some documentation on it. I can try to find it for you if you're down to replace it. The hard part though is confirming you're replacing the correctly needed switch as a one-off, verses dropping the money to just replace all 6. If you want the car to last forever, there's merit in replacing them all but it'll be expensive, especially if you have someone else do it. If you do it yourself, it's relatively easy and OEM parts will cost you maybe like $400.
Poolman (07-31-2024)
Thank you TSB. I believe I'm relatively handy, I did the brake job on the car, have worked on old Rovers, etc..... Are the switches tough to get to? Are there videos on line? If you have documentation, I'd love to see it. Thanks.
Third gear pressure switch DIY link
https://acurazine.com/forums/2g-rdx-...cement-993904/
Hope that helps
While at it read the next link with consideration towards Valvoline Maxlife transmission fluid
https://acurazine.com/forums/2g-rdx-...roller-966971/
Hope that helps
Hope that helps
Hope that helps
Thanks everyone.
One more item.....are all the pressure switches the same part number? I know I need to confirm the 3rd pressure sensor to replace, but, are all the actual sensors,
the same part number? thanks.
One more item, where's the best place to buy a new pressure switch? OEM dealer or other????
Are the sensors exactly the same? If I wanted to replace more than one, are the switches interchangeable or are they specific to one gear?
Thanks,.
Thanks,.
