rear door component set for base model RDX
Old Sep 2, 2019 | 01:14 AM
Mikel P's Avatar
Replaced the 6.5 components up front, and was recommended coaxial 6.5's for the rear doors. I was not happy with the sound as it was all firing downwards and created too much of a front stage from the upfront speakers other wise. So I swapped them out for another component set.
Popped off and removed the door panel, used a compact palm router to buzz open a hole for the tweeter (be sure to remove the white cotton foam) and voila. Took about an hourish per door
Definitely balances out the sound with a nice surround effect. Tweets are swivel mount, so can adjust angles.
They are running off the stock amp setup and all sounds very decent, big improvement over the flimsy yellow stock speakers
Attached Thumbnails rear door component set for base model RDX-img_20190811_020301288.jpg
DJF
1G RDX (2007-2012)
May 8, 2014 05:02 PM
droebuck
1G RDX DIY & FAQ
Nov 14, 2013 10:22 AM
John Echols
Jun 26, 2012 12:03 AM
speedracer_2020
Apr 22, 2012 04:03 PM
09TSXCC
2G TSX Problems & Fixes
Aug 25, 2010 06:10 AM
