RDX engine start sounds like rough sewing machine
Old Jan 11, 2025 | 09:41 AM
RDX_2017's Avatar
4th Gear
Hi everyone, my 2017 rdx started making a never before heard noise when starting up the car. This new noise started happening a few months ago in 2024.
i have not been able to find a pattern or area of the engine that I could identify as the source.
the curious part is that sometimes in the morning the engines starts up quiet, like it has behaved in the past. I lice in LA and weather here has maybe been in the mid 50’s when i first started noticing this issue. Acura cerritos couldn’t help even with the videos nor did my new mechanic.
this can’t be normal and the experts haven’t provided any insight.
thought I give this forum a try. Thanks
https://dolby.box.com/s/qmixjdfg5bdkwf90gvxuy2jocawpgp68
Old Jan 11, 2025 | 02:12 PM
Poolman's Avatar
How many miles, and has the timing belt been changed ?
Old Jan 11, 2025 | 09:35 PM
RDX_2017's Avatar
4th Gear
hey Poolman,
87,000 plus miles. Timing belt was replaced a couple years ago.
Old Jan 12, 2025 | 02:43 PM
MM17RDX's Avatar
Probably a failing timing belt tensioner
Old Jan 12, 2025 | 03:49 PM
RDX_2017's Avatar
4th Gear
thanks MM17RDX will check that out
Old Jan 14, 2025 | 09:42 AM
Poolman's Avatar
Have noticed that in engines with weak timing systems, first indications of the problem begins with what you are describing when starting your car.
Old Jan 14, 2025 | 10:11 AM
MM17RDX's Avatar
Bad tensioner sound..
Nates NJTL
Feb 10, 2023 10:49 AM
j_wael08
3G RDX (2019+)
Aug 11, 2022 07:43 PM
98GTSViper
Dec 13, 2021 06:13 PM
Pilsner332
2G RDX Problems & Fixes
Jun 14, 2017 01:44 PM
Lalin
Dec 22, 2016 02:34 AM
