Intermittent P0328 ("Check Emission System") Code
Old Oct 23, 2025 | 02:29 PM
ArmchairArchitect's Avatar
Arrow Intermittent P0328 ("Check Emission System") Code
Got the "Check Emission System" warning recently on my 2016 RDX but only on some trips. Other trips its completely gone.
Ran the codes with my OBD code reader and got P0328.
My understanding is that this code is not that a knock was detected but rather that the sensor itself is giving inaccurate readings out of range- indicating a faulty sensor rather than a knock condition. Is this correct?
Looks like its a time consuming job to replace so I'd like to try/rule out some easier things to fix it first.
Any tips?
Old Oct 24, 2025 | 06:49 AM
altair47's Avatar
Any tips?
First, visually inspect what might be causing the knocking, such as the intermediate shaft bearing or something hitting the engine. If everything is fine, then the knock sensor needs to be diagnosed and most likely replaced.
Old Oct 30, 2025 | 04:12 PM
My understanding is that it would be a different OBD code if the engine was actually knocking and that code P0328 means either the sensor or wiring has a fault.
The engine runs very smooth, and even running 94 octane doesn't make the code go away, which sort of reinforces that its an issue with the sensor or wiring.
Jakec
Oct 11, 2023 02:20 PM
Edwin Martinez
Jul 20, 2016 07:48 AM
furnac3
Aug 17, 2011 02:05 AM
PACman
1G TSX Problems & Fixes
Nov 15, 2006 11:16 AM
Ysidro
1G TL (1996-1998)
Dec 16, 2005 07:34 PM
