whats this error code?
Old Dec 11, 2005 | 05:53 PM
Ysidro's Avatar
hi folks.
After cleaning the egr valve an chamber, now I have another one.
I went to autozone to let them do a odbc scan and found this error code.
It is P1660.
does anyone know what the problem is ?
Anyone experience it?
Thanks in advance.
Old Dec 11, 2005 | 06:24 PM
demons rage's Avatar
That code is...
A/T FI Signal A Circuit Failure
might be a failure in the sensor in the transmission or soemthing if there is one...
Old Dec 11, 2005 | 11:07 PM
Ysidro's Avatar
Hi,
does the transmission have a sensor like an oxygen sensor or something?
Anyone know where to start?
Old Dec 16, 2005 | 07:34 PM
TexasHonda's Avatar
This is a data line failure between ECM and TCM. First thing would be to reset the ECM/TCM and hope it does not return. If the code returns, you have a wiring fault that must be traced using the shop manual for your vehicle.
You might try another scanner. Sometimes a faulty scanner can cause all sorts of headaches.
regards
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
