2018 RDX jack points
Old Sep 16, 2020 | 12:40 PM
tinmaner's Avatar
hello all
so i have been trying to identify Jack points on 2018 RDX just to be ready incase i have a flat .. but i couldnt possibly locate ..
i took pics of the under bottom but still dont see how it is showed in the manual ..
can someone who has experience post a pic of the under showing jack points please ?
thanks in Advance
Old Sep 16, 2020 | 12:46 PM
the subframe has a square indicator or jack point in the front of the car.
Old Sep 16, 2020 | 12:47 PM
Old Sep 16, 2020 | 12:56 PM
tinmaner's Avatar
hello @justnspace thank you very much .. i will look and see if i have that on the back ..
but im looking for the ones on the side that can be used for a regular jack that comes with acura ..
like in this pic
Old Sep 16, 2020 | 01:20 PM
yes, you can also use the pinch welds.
the front and back will have the square denoting the jack point
Old Sep 16, 2020 | 01:38 PM
that jack is anything but regular.. it's a scissor jack meant to replace a flat tire in a pinch, i wouldn't use that to do an oil change
Old Sep 16, 2020 | 02:33 PM
yeah, it needs to be on stands. the pinch welds are there for the jack stands.
Old Sep 17, 2020 | 08:29 AM
tinmaner's Avatar
Any pic of the underbody showing clearly where i need to put it ?
Old Sep 17, 2020 | 08:39 AM
Mo_Green's Avatar
For safe oil changes: Use jack stands on the side pinch welds. Always. Take the jack and move it to the rear lower control arm mount on the driver's side. You can gain access from under the front side doors. Engage the jack slightly with the control arm mount. The safety jack is now out of the way for all your fluid changes.
Old Sep 19, 2020 | 09:15 AM
Brown13's Avatar
Sorry that everyone assumes that You want to change oil, rather than understand what a Jack point looks like. Here
Old Sep 19, 2020 | 02:18 PM
it's not a jack point, it's a pinch weld.
Old Sep 19, 2020 | 08:29 PM
Brown13's Avatar
Ok It's a pinch weld,but that's where You place the scissor jack when You need to change a tire.
ThermonMermon
May 23, 2018 12:39 PM
S2000 GUY
Sep 15, 2008 06:50 PM
AznX TL
Aug 12, 2007 11:54 PM
NiteQwill
Mar 26, 2004 02:54 PM
