need advice (tranny)
I have a 02 type S Cl automatic 75k miles. When I'm going around 20-40mph it has a hard time catching gears and jerks real hard when it does. No VSA light came on or check engine light and no D5 flashing. And it doesn't do it all the time but it just started last week. I have appointment at the dealer tomorrow but i don't want to take it and have them look at it and tell me nothings wrong and charge me. (since no indicators are on) Should I wait until a light comes on or take it to dealer? Sorry if this is in the wrong forum or a repost. So many tranny threads
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
"You my boi blue!"
Your tranny is about to die more than likely....depends on the dealer on what they will do. MOST dealers, if they cannot reproduce the slippage will not replace the transmission. I took mine in 2-3 times and they couldnt reproduce it, then one day my tranny went out and left me on the side of the road. Good luck, hopefully they realize that this is a huge safety issue and should address it very quickly
1st and 2nd Gen. CL'er
Originally Posted by marcy69
do the dealers normally charge you if they can't reprodece the problem?
![behead](https://acurazine.com/forums/images/smilies/behead.gif)
M to da DZ
I have a 02 type S Cl automatic 75k miles. When I'm going around 20-40mph it has a hard time catching gears and jerks real hard when it does. No VSA light came on or check engine light and no D5 flashing. And it doesn't do it all the time but it just started last week. I have appointment at the dealer tomorrow but i don't want to take it and have them look at it and tell me nothings wrong and charge me. (since no indicators are on) Should I wait until a light comes on or take it to dealer? Sorry if this is in the wrong forum or a repost. So many tranny threads ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Parting out 02 Type S :(
if you are absolutely sure it does NOT run properly even sometimes, you should take it in. if you car is exhibiting problems synonymous to failing trannies, you should have them check it.
the worst they can do is charge you 75 bucks for the inspection, which you would be refunded when the tranny does give out! of course, they wont offer the refund unless you mention it
I'm here in spirit...
Mine did that once, at least I thought it was doing something screwy. When I would slow down, then proceed to accelerate, it felt like it was confused as to which gear to select. I took it to the dealer along with the rest of my dirty laundry. They checked it out and told me it was fine and didn't charge me anything.
I just had my transmission replaced 2 months ago. My CL had about 68,000 miles on it. It would shift wierd when going into 2nd and 3rd. Nothing major just kinda wierd. So I took my car into the dealership (Price Acura) to have the brakes replaced. I just casually told them that trans was acting weird. They said they would take it for a drive and see if they could find anything wrong. After about an hour I got a call telling me that they will be replacing the transmission. I had no warnings, no lights, no noises. So with the symptoms you are saying I am sure there will be a good chance they will replace it. Hope everything goes well.
Just tell them to drive it and recreate the problem.. if it is doing it all the time surely they will feel it and hook you up with a new one... i know thats what they did with me! i didn't have any lights w/ my first one either...
Whats Good? CL
yeah i think this is probably bad......mine is just starting to slip and i have 163,000 miles...been perfect till this point...not bad at all yet...but i have a feeling gonna get bad....we can mourn our trannys together
![Bawling](https://acurazine.com/forums/images/smilies/bawling.gif)
Originally Posted by Blocked Shots
yeah i think this is probably bad......mine is just starting to slip and i have 163,000 miles...been perfect till this point...not bad at all yet...but i have a feeling gonna get bad....we can mourn our trannys together ![Bawling](https://acurazine.com/forums/images/smilies/bawling.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Pham Alvan
03-16-2016 09:17 AM
soupi
14
11-15-2015 11:15 AM
