View Poll Results: If you had a chance to look at (inspect) your Comptech springs, are they?
In perfect condition. With No visible marks. IOW, they look great.
21
29.17%
Have some marks and/or pits. (Comments?)
23
31.94%
Corroded (Please comment with location and other info)
22
30.56%
Other: explain what's going on/what you see...
8.33%
Voters: 72. You may not vote on this poll
Can you check your Comptech Springs?
Old 09-23-2004, 09:31 PM
  #441
an adult perspective
Six Shifter's Avatar
Originally Posted by mrsteve
The Koni's allow for minor height adjustments. I believe the maximum difference from lowest to highest is 1/2"
If I'm not mistaken, the "standard" Koni Yellows have 2 perch settings for the front, and 3 for the rear shocks. As Steve says, they allow for minor height adjustments ... the Koni's can lower the car about 20mm (info from their website). In my case, I believed I needed the Neuspeed's because they have 5 perch settings on both ends, which helped to compensate for the system in the trunk. Neither Comptech, Koni nor Dean would/could assure that (based on my particular situation) the typical Comptech/Koni Yellow combo would allow me to level out the car. Without having a set of "standard" Koni's to compare to, I don't know if the overall distance from the bottom perch to the top is the same on the Koni's as it is on the Neuspeeds, but at least I had two/three more options on each shock. I think the route I went worked extremely well, as you can see.
Old 09-23-2004, 09:35 PM
  #442
Audi S4 driver
blader's Avatar
I see. I never knew that. I always assumed that when people talked about the "perches" of the koni's, they were talking about dampening for some reason .. never knew they were height adjustable as well. thanks guys
Old 09-23-2004, 09:36 PM
  #443
mrsteve's Avatar
You learn something everyday on A-CL don't you?
Old 09-23-2004, 09:39 PM
  #444
Audi S4 driver
blader's Avatar
^you'd be surprised
Old 09-24-2004, 02:40 PM
  #445
Spectacular Aroma About
ChadT's Avatar
Originally Posted by Y2K3CL-S
to me the pic of the passenger side rear looks like there is more space than on the drivers side rear.
This is probably from the surface the car is sitting on not being perfectly level. Park the car in a few different locations and see if it changes. I may have to raise mine another notch in the rear and drop the front. I really like the way your car is sitting.
Old 09-24-2004, 05:42 PM
  #446
6speedctrlfreak's Avatar
For anyone who had their CT Springs purchased & installed at PAA in NJ and are still under warranty -
Do they have the 'new' (black?) springs ?? and are they handling the return & labor reimbursement with CT for you ?? (I kind of remember someone mentioning this previously)
I have looked at mine and they are rusting---- am under warranty until 05/05 , so thank you sweet
Old 09-24-2004, 05:54 PM
  #447
Jonesi's Avatar
I believe Shawn S could provide some insight for you..
Old 09-25-2004, 11:24 AM
  #448
Jonesi's Avatar
Joe called me back and verified the ride height is the Eibach ride height now.. More then likely we will need camber kits for the new springs.. So tact on another $100-$200 more on top of what I've already paid.. I'll be at a total cost with these junk springs over $1,200.. Also the stock shocks which have previously lasted me 67k miles.. More then likely the stock shocks will not hold up as long as they did with the other springs..
Old 09-25-2004, 11:29 AM
  #449
ChadT's Avatar
What a f#*!ing bone job!!! I wish I would have known this before I put the springs on my car.
Old 09-25-2004, 11:41 AM
  #450
Doin' da crack shuffle
Red-CL's Avatar
Now that just fuggin sucks.
  #451
Red-CL's Avatar
When and/or if my springs crap out, I'm moving to another brand. I already got Koni Yellows but don't wanna lower my car anymore. I'd rather take a $300 and Saturday hit (did my own install) than to have to keep spending money on my suspension setup.
Old 09-25-2004, 11:44 AM
  #452
So, we have Carl telling us that in his conversation with Comptech they confirm that the springs are now Eibach springs ... and we have Jonesi telling us that Comptech confirms the ride height of the 'new' Comptech springs are in fact the same ride height of the Eibach springs - which by association means that we are talking about the Eibach Pro-Kit Spring Set ... which retails at TireRack for $238 for the kit ... which means that those of us who have returned the springs have now received a replacement item which was marked up by 25% over what we could have gotten it for from TireRack (in other words Comptech has replaced their $299 springs that we paid $299 for with an item that sells for $238)?
Old 09-25-2004, 11:47 AM
  #453
Jonesi's Avatar
I went to www.groupbuycenter.com last week and saw Eibachs for $199 shipped..
But yes Joe told me after speaking with a technican that the new height is 1.7, 2.0 exact same as the Eibach..
Old 09-25-2004, 11:49 AM
  #454
ok ... so we are getting screwed to the tune of anywhere between $61 and $100 - even more when you add shipping to the equation.
Old 09-25-2004, 12:18 PM
  #455
Audi S4 driver
blader's Avatar
they are robbing us blind. no wonder they agreed so willingly to give you a set for 200 if your out of warranty .. because you can get the exact same springs for cheaper than that!
I bet if they still had the old springs you would've been buying a set for 299$
god am I glad I went with tein
Old 09-25-2004, 12:24 PM
  #456
Jonesi's Avatar
On top of that labor...
Camber kit..
Shocks, b/c factory shocks won't hold up as long..
The list goes on and on for me..
I'm out approx. $1,200 so far...
Old 09-25-2004, 09:05 PM
  #457
I now drive an accord....
spdy0001's Avatar
Well comptech officially changed the drop height on their site I just hope I can return my springs
Old 09-25-2004, 10:59 PM
  #458
Shawn S's Avatar
My saga has ended.
Comptech’s are OFF and the TEIN coilovers are ON.
Full report to follow in a new thread in a few days.
Good luck to everyone else in their negations with Comptech on getting these rusty pieces of crap replaced.
Old 09-26-2004, 12:41 AM
  #459
wondered why we hadn't heard from you 'bout ur Teins
Old 09-26-2004, 01:22 AM
  #460
Blown is Best
Allout's Avatar
I'm also going to have to jump on the bandwagon of disappointed people on this issue. I really wish that they would have worked through their issues with manufacturing and not thrown in the towel on this one. They didn't even correct the installation instructions sent with the Comptech/Eibach springs.
Eibach does not differentiate their left and right springs whereas Comptech used to. Their instructions still reference the tags attached to each spring that indicate spring load/rate. My springs had no tags attached. Did anyone else have tags attached? I doubt it. I always considered the Comptech springs a step above because of this additional step that they did in their quality process to rate and match the springs as a set.
Oh well. I'll install mine tomorrow and hope for the best. I'm running Illuminas so I don't have the option of lowering or raising the perches like the Koni's do.
Old 09-26-2004, 09:02 AM
  #461
dj5
dj5's Avatar
I am a little conerned about needing a camber kit when replacing the old Comptech spring with the Eibach springs since the drop is more.
In looking at other springs, it seems that the HR Sport are a closer drop to the old Comptech springs. I my just leave my Comptech springs on until one breaks then replace with HR Sport springs and Koni Yellow.
Old 09-26-2004, 09:36 AM
  #462
Where is my super sauce?
Slimey's Avatar
I'm in the same boat. I'm not interestested in slammed look -- I liked the conservative drop of the Comptech. I was also thinking of going with H&R Sport + Koni Yellow.
The question for me is timing -- I'm sure I have another 6 mos to 1 year with the Comptech Springs (they just have a light rust on the bottom coils).
This really does bum me out.
Old 09-26-2004, 11:05 AM
  #463
Red-CL's Avatar
Quite a few of us in the same boat except I already got the Koni Yellows.
I think I'll go with the Tein Luxury springs. They have the exact same drop as the previous Comptech drop.
Old 09-26-2004, 01:24 PM
  #464
dj5
dj5's Avatar
Here are the drops listed on Autocarparts.com
Comptech (silver) 1.75/1.50 $275.08
Eibach Pro Kit 2.10/1.75 $210.54
H&R Sport 1.75/1.50 $185.53
Neuspeed 1.75/1.75 $155.96
Tanabe 1.50/1.50 $234.00
Tein Luxury 1.50/1.00 $195.00
I would consider going with either the H&R sport or the Tein Luxury. And we all thought we were paying a premium price for springs to get the Comptech quality.
Eibach springs do have a 10 year warranty, I wonder if you buy them from Comptech if it goes down to two years.
Old 09-26-2004, 03:01 PM
  #465
I Want a GPW 03 S2k
cdrink80's Avatar
So what now is comparable to the old Comptech Springs, im looking for a reasonably easy suspension setup, nothing to complicated....would i need a camber with the Tein Luxury, and how do u think those will compare to the old comptechs?Thanks
Old 09-26-2004, 03:03 PM
  #466
Smitty's Avatar
Has ANYONE linked the TL-S guys to this thread?
Old 09-26-2004, 06:09 PM
  #467
mrsteve's Avatar
There is a TL thread, although it only has 2 pages.
TL = teh slackers
Old 09-26-2004, 08:58 PM
  #468
dj5
dj5's Avatar
I have a '02 TL-S and I visit the A-TL site but I like the A-CL site much better. More knowledgeable people here. Seems the TL site is now mostly a bunch of teenager who have inherited mom or dad's TL.
Back to the topic. I am still undecided, but right know I think the do nothing option is gaining popularity with my wallet.
Old 09-26-2004, 09:23 PM
  #469
hemants's Avatar
This is really ridiculous. If Comptech was going to send out a replacement spring from a different company, they should have shipped H&R 50103. The drop is almost identical to Comptech.
This whole things begs the question, how is it that Comptech got such a great reputation in the first place???
I remember specifically buying Comptech because of their reputation on this site and a-tl
Old 09-27-2004, 07:56 AM
  #470
Red-CL's Avatar
Eibach could have been doing the Comptech Spring s in the first place. If so, I'm pretty sure they wouldn't change vendors.
Old 09-27-2004, 08:02 AM
  #471
Red-CL's Avatar
Comptech has been doing very well for a number of years as far as quality goes. They're also the main aftermarket manufacturer for Honda/Acura.
I'm unhappy about the whole situation too but they've only had problems with their springs.
Old 09-27-2004, 02:22 PM
  #472
1SICKLEX's Avatar
Sigh.
Old 09-27-2004, 02:32 PM
  #473
1SICKLEX's Avatar
Originally Posted by Shawn S
Here is the UGLY truth about the quality of these springs.
FRONT DRIVERS SIDE
FRONT PASSENGERS SIDE
REAR PASSENGER SIDE
REAR DRIVERS SIDE
A FEW CLOSE-UPS OF THE REAR DRIVERS SIDE
Since ya'll have not kicked anyones ass, ya'll are the nicest dudes on the planet. Aftermarket springs are supposed to be battle tested and a higher quality than any stock OEM componant.
Eibach is great quality stuff.
Tein is top of the line stuff. Finally expanding to Euro cars.
Old 09-27-2004, 02:36 PM
  #474
Jonesi's Avatar
I'm glad I don't live anywhere near comptech...
Old 09-27-2004, 02:50 PM
  #475
Smitty's Avatar
Lol
Old 09-27-2004, 03:06 PM
  #476
Blown is Best
Allout's Avatar
I know everyone's ticked about getting the Eibach drop on the new springs. I just installed mine last night and this is the drop I got on my set:
1.625" (left front) 1.750" (right front)
1.375" (left rear) 1.375" (right rear)
This was replacing the stock springs and struts (20K miles on them) with the Grey Comptech Springs and Tokico Illuminas.
Drop is comparable to the old Comptech Silver springs - unless these are going to settle another 1/4"
Old 09-27-2004, 03:08 PM
  #477
Jonesi's Avatar
They will settle... Took about 2 weeks but mine came down a bunch...
Old 09-27-2004, 03:11 PM
  #478
Blown is Best
Allout's Avatar
That sucks. I like the way it looks right now. Once I add the SC in a couple of weeks, it's going to add another 60-70lbs up at the nose too.
Old 09-27-2004, 04:08 PM
  #479
I Want a GPW 03 S2k
cdrink80's Avatar
so what is the next best srping that i most similar to the old comptechs
Old 09-27-2004, 04:09 PM
  #480
Jonesi's Avatar
I would say either HR or Eibach..
Quick Reply: Can you check your Comptech Springs?
