washer fluid issues
washer fluid issues
my washer fluid wouldnt spray so i thought it was empty. bought some and popped the hood. the cap would pop off but wouldnt pull the dipstick out and it is seemingly stuck in the tube. i added some fluid and it wouldnt go into the resevoir. anyone had this issue or even heard about it?
Originally Posted by fuzzy02CLS
Never heard of that. Is it totally stuck? You can't yank it out? Pry on it? If it breaks I see no real use for that dipstick thing anyway.
follow up: definately frozen
2 nights in thew garage with the heat up and the hood up thawed it. i sprayed all the bad fluid out and filled it with rain x fluid. no problems since. thanks for your help guys i did not think that washer fluid froze.
washer fluid gets thicker when it's -20C outside but it doesn't freeze. I bet he had water in there. Did you lend your car to anybody not competent enough to know that you can't put water in there?
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
Mike Bertram
09-10-2015 09:27 AM
