washer fluid issues
Old Jan 22, 2007 | 07:07 PM
aveisone's Avatar
washer fluid issues
my washer fluid wouldnt spray so i thought it was empty. bought some and popped the hood. the cap would pop off but wouldnt pull the dipstick out and it is seemingly stuck in the tube. i added some fluid and it wouldnt go into the resevoir. anyone had this issue or even heard about it?
Old Jan 22, 2007 | 07:34 PM
fuzzy02CLS's Avatar
Never heard of that. Is it totally stuck? You can't yank it out? Pry on it? If it breaks I see no real use for that dipstick thing anyway.
Old Jan 23, 2007 | 09:39 PM
aveisone's Avatar
thanks for your response. yes absolutely stuck i pulled as hard as i could and the blue cap seperated from the dipstick. could it be frozen... perhaps some water found its way down there. im somewhat baffled.
Old Jan 23, 2007 | 11:53 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Take the bumper off and see what's going on under there. Could be the washer fluid is frozen, though I've never heard of that happening.
Old Jan 24, 2007 | 07:33 AM
fuzzy02CLS's Avatar
Do you live where it gets cold? It may be frozen. Try running a hair drier on the tube.
If that is a no go then I agree taking off the bumper is the next thing to do.
Old Feb 2, 2007 | 10:38 PM
aveisone's Avatar
follow up: definately frozen
2 nights in thew garage with the heat up and the hood up thawed it. i sprayed all the bad fluid out and filled it with rain x fluid. no problems since. thanks for your help guys i did not think that washer fluid froze.
Old Feb 2, 2007 | 11:07 PM
I never knew washer fluid froze either. Guess you learn something new everyday.
Old Feb 3, 2007 | 05:07 AM
belcom's Avatar
09 TL SH-AWD
washer fluid gets thicker when it's -20C outside but it doesn't freeze. I bet he had water in there. Did you lend your car to anybody not competent enough to know that you can't put water in there?
Old Feb 4, 2007 | 09:15 AM
Sounds like something a dealer would do.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Mike Bertram
Sep 10, 2015 09:27 AM
