Transmission Fluid Flush
Old Jan 4, 2006 | 08:52 AM
inbluedesign's Avatar
Does anyone know when this is supposed to be done? My dealership says factory is 120k but they recommend it be done at 90k. I thought is was 60k? My fluid is muddy and am at 67k right now.
Old Jan 4, 2006 | 12:21 PM
daniel951's Avatar
i was curious about the same thing. I am at 82k and i am unsure if it has ever been done or not.
Old Jan 4, 2006 | 12:26 PM
phipark's Avatar
Not Asian
The manual specificly states 60k.
Old Jan 4, 2006 | 12:43 PM
Thanks, guess it's time... at $130 smacks! grrr...
Old Jan 4, 2006 | 02:06 PM
daniel951's Avatar
i called the dealership yesterday and they said it was 50 bucks for a transmission flush
Old Jan 4, 2006 | 02:21 PM
hmmm i called 2 and they said $115 and $125..
Old Jan 4, 2006 | 04:15 PM
daniel951's Avatar
sounds like they are just trying to make more money . Another option u can do is go to somewhere else other then a dealership. Someone that is a reputable company
Old Jan 6, 2006 | 02:34 PM
Davidstingray's Avatar
I do a three quart transmission “drain and fill” with Honda Z-1 fluid each year during my annual engine oil change (Red Line Synthetic 10/30). This replaces 1/3 of the transmission fluid each year and keeps it very clean.
Old Jan 20, 2006 | 07:05 PM
msvara's Avatar
I agree with Davidstringray. My dealership told me to change the tranny fluid every 25,000KMS especially for the 01 - 03 CL/TL. I had them flush mine when they did the transmission inspection recall and 1 year later it's brownish. Alternatively you could add Lucas Transmission Treatment. It's a great liquid that'll refresh the tranny fluid for at least a few more months. Nothing beats an actual flush with the recommended Honda fluid but if you can't afford to do it every year then try Lucas to extend the life.
However. If you've never changed the tranny fluid and you're at 80000K DO IT RIGHT AWAY!
Old Jan 22, 2006 | 05:30 PM
Too late everyone, my tranny blew up on Friday!! I really had a feeling something was really wrong! It's under warranty still thank goodness!
Old Jan 25, 2006 | 10:03 AM
welphd's Avatar
Still under warranty? did you do the tranny recall?
Old Jan 26, 2006 | 10:35 AM
Yes I did...why?
Old Apr 29, 2014 | 08:35 PM
Sweeper's Avatar
I have a 2003 CL and having a problem locating the drain plug. Is the drain plug the one that requires a square tool to insert into the plug???? If so, would you know what size tool?
Old Apr 29, 2014 | 10:29 PM
Rapture's Avatar
^^Yep, that sounds like it. if I remember correctly it's just a 3/8" ratchet. No specialty tools needed.
Old Apr 30, 2014 | 11:23 AM
Tosh's Avatar
Eurotrash
Best make sure the fill plug comes out before undoing the drain plug!
Old Apr 30, 2014 | 07:40 PM
Rapture's Avatar
^^THAT one is the worst. I had to use a high torque impact wrench to get that damn thing off! And when I finally got it off the washer was chewed up so bad from the excess torque.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
steve
Sep 30, 2015 09:23 PM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
