Timing belt changd today..
Old Mar 4, 2010 | 06:13 PM
oreo615's Avatar
Well,I had my timing belt and water pump changed today by my local garage.Total bill..$504.35 {$151 for parts and $28 tax } boy was i happy ! I was surprised though to see the old belt in like new condition,it was hard to tell the old from the new the old belt showed no cracks or wear.The mileage on the car is 116,000 miles.
Old Mar 4, 2010 | 07:27 PM
aznboi2424's Avatar
what else did you change?
didnt bother doing a complete 105k?
Old Mar 5, 2010 | 06:09 AM
oreo615's Avatar
I do regular maintenance on my car. I didnt want to tackle the belt.
Old Mar 5, 2010 | 07:25 AM
pits200's Avatar
Well when you say T-belt change, you do mean that you changed the water pump, tensioner and seals, too, right?
Old Mar 5, 2010 | 06:44 PM
aznboi2424's Avatar
x2, thats what im asking. but looking at the price he paid he probably only got t-belt and water pump
Old Mar 5, 2010 | 07:07 PM
pits200's Avatar
Ya I figured that's what you meant but I wanted to steal the credit for clarifying, lol.
Old Mar 5, 2010 | 10:49 PM
celynka's Avatar
Sundance Gold in
TB may look like brand spanking new but @ 116k its internal structure is severly weakend. $500 is an average for this kind of repair, it takes about 3 hours to complete...
Old Mar 9, 2010 | 12:10 AM
Nersh7's Avatar
I Drive Like A Dick 8≈
Is there any different types of timing belts for us?? other than OEM, somewhat like the Cadillac chain timing belt or something like that??
Old Mar 10, 2010 | 06:03 PM
pits200's Avatar
Lol what..
Some cars having timing chains and some cars have timing belts.
We have belts as you know and yes you can buy an aftermarket belt if you wish, you don't need to go with OEM. But being that its not much cheaper to buy aftermarket and the OEM one is proven durable being that its been on the car already, I would just stick with that one.
Old Mar 10, 2010 | 08:09 PM
Nersh7's Avatar
not sure if that was a question or not
but ya chains, and they are way better. this guy I know said that it only has to be changed once every 500 000 miles rather than 105 000. I was just wondering if there is anything better than oem that we know about?
Old Mar 10, 2010 | 09:00 PM
pits200's Avatar
Well chains aren't necessarily better.
1.) they are noisier
2.) they can stretch
Old Mar 10, 2010 | 09:40 PM
aznboi2424's Avatar
and you still would need to replace cam seals, valve cover gaskets, water pump, valve adjustment, tensioner, etc with a chain. The only part you dont need to touch is like a 35 dollar belt.
just because your chain lasts 500k doesnt mean everything else on the engine will
Old Mar 10, 2010 | 10:50 PM
Nersh7's Avatar
great points guys I was just curious if there was something better
Old Mar 14, 2010 | 11:11 PM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
i've done 2 t-belt jobs so far, and both times the old belt looked just about as good as the new one. but like celynka said, looks can be deceiving. the thought of leaving the old one on crossed my mind for a split second, but it's def not a risk i'd be willing to take.
Old Mar 14, 2010 | 11:19 PM
VENOME1's Avatar
Your forgetting that chains are heavier than belts. Chains are needed in non interferance engines where if it failed the valves would hit the top of the pistons.
Old Mar 17, 2010 | 10:04 AM
Zippee's Avatar
Can you explain, please?
Old Mar 21, 2010 | 02:32 PM
celynka's Avatar
Sundance Gold in
No explanation for that . That was just sarcastic BS
Old Apr 16, 2010 | 07:41 PM
ChickenCoupeCLS's Avatar
i have 145000 miles and neva changed my timing belt or water pump ... wha do yall think bout that?????/
Old Apr 16, 2010 | 07:52 PM
aznboi2424's Avatar
are you asking for advice or are you taunting?
you need to change it or risk getting a new engine.
Old Apr 17, 2010 | 12:32 PM
rageoner99's Avatar
4th Gear
not a good idea
Old Apr 17, 2010 | 03:24 PM
hermtm2's Avatar
What I've done the job at the last year on my garage. It took me 2 days to align the cams and cranks. Also cost $300 for the parts. Now as good as new.
timing belt
water pump with gasket
thermostat and gasket (not pictured)
timing belt tension adjuster
timing belt tensioner
timing belt idler
both accessory drive belts
front crankshaft seal
two front camshaft seals
Old Apr 17, 2010 | 06:44 PM
aznboi2424's Avatar
i did my upper and lower radiator hoses too but not my thermostat yet.
hope you got your valves adjusted too, its a good improvement.
Old Apr 19, 2010 | 11:25 AM
thanx 4 the advice
Old Apr 21, 2010 | 09:49 AM
abernja's Avatar
I need to have my 105K maintenance done..........but that $900 Acura bill is VERY scary lol.
Do you think I'll notice a difference in how the car performs once the job is completed? I feel like it's lost some "spunk" especially in the lower gears. Doesn't seem to pull off the line as fast as it used to and the engine just seems kinda weak.
Old Apr 22, 2010 | 12:16 AM
aznboi2424's Avatar
after parts and labor I shelled out over 1000 dollars. I did it without complaints because I knew it was being done right and that it would ensure that my engine would last another 105k.
I felt a gain in power probably due to the spark plug change and the valve adjustment.
Old Apr 22, 2010 | 11:12 PM
8my-cls01's Avatar
Triple "T"
don't forget about the power steering and a/c belts
Old Apr 23, 2010 | 10:03 AM
aznboi2424's Avatar
"both accessory drive belts"
that what those are.
Old Jul 29, 2021 | 09:41 PM
emry's Avatar
How did you replaced these two? Do you have any details or pix?
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
