My trans wont shift out of first
Old Jun 1, 2010 | 02:09 AM
TarzanCLS's Avatar
i have been losing my mind about this all day. I was driving this morning for about 30 minutes around town, all was fine in D5. the light went green and the car stayed in first gear. i put it into SS it said 1, pushing up and down, nothing, gate shifted down to D1 then back up to D5, nothing, sitting high rpm. pulled over and turned it off then back on. and it would go through all of the gears really high, to 4-5k, then shift. no slipping at all, just high rpm hard shifting. slowly went home and parked it. my scanner says, no system errors, no running codes, no pending codes. NOTHING! ive been on here all day, shitting a kitten in research. only thing i can come close to in searching is TPS. anything anyone??? PLEASE???
Old Jun 1, 2010 | 10:22 AM
phee's Avatar
I got the Shifts
your trans is done.
Old Jun 1, 2010 | 11:20 AM
PANAMARED's Avatar
fluid level?
Old Jun 1, 2010 | 02:33 PM
TarzanCLS's Avatar
bright red, unburnt, and perfectly level....
Old Jun 1, 2010 | 10:41 PM
VIPCLS's Avatar
P.
I've never heard of the tranny doing that in 1st?
Old Jun 2, 2010 | 12:02 PM
PANAMARED's Avatar
i am no expert but sounds like electronic... personally do not think is the actual tranny itself... there are some sensors in tranny that controll shifting (sends signal to ecu and back)... i know they are sometimes replaced... sorry for my rookie opinion (trying to help back, always get great help here)
Old Jun 2, 2010 | 09:29 PM
TarzanCLS's Avatar
update, i drove it today and it shifts by itself at 3,500 RPM with a massive bang. if i put it in SS mode, it still waits until 3500rpm to shift to 2nd, then i can shift it myself in SS up and down the gears. also still accompanied by an extremely hard shift. still no transmission codes....
Old Jun 2, 2010 | 09:31 PM
Jacobpockros's Avatar
Yeah, your tranny is definatly going out.
Sorry to hear about that. Too many 1/4's
If it gets worse, you can probably get a rebuilt one for $1900
Old Jun 3, 2010 | 09:59 AM
StreetKA's Avatar
found this may help someone
http://philadelphia.craigslist.org/pts/1713290098.html
Old Jun 3, 2010 | 10:11 AM
DarkSithCL's Avatar
Be Strong AND Courageous!
I have been here a while on AZ and I am on my 3rd tranny, with 153k on the chassis but thats never been a problem of mine... in fact I have not heard of the "bang" youre speaking of either... before it goes BANG again for good, I would get someone to look at it... i hate to tell you that, but I dont know of anything else you can do at this point... maybe some of the mechanic heavy duty folks here has an option????
Old Jun 3, 2010 | 10:17 AM
NSXNEXT's Avatar
When I had that same symptom is was due to a faulty throttle position sensor (TPS) HOWEVER I did have a CEL (I believe it was P0121).
And you're not throwing a CEL? I find that strange.
Old Jun 3, 2010 | 10:40 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Any trans I ever seen that holds a single gear,or will not engauge in others is smoked.
Old Jun 3, 2010 | 12:05 PM
PANAMARED's Avatar
thing is that it is not slipping... tranny has sensors that control shifting... once i had a similar problem but with different car; back then it was the passing gear cable that goes to tranny, had snaped and kept in a "pull" position. Anyhow: the tranny posted by streetKA looks very good
Old Jun 7, 2010 | 10:54 AM
StreetKA's Avatar
any update on that?
Old Jun 7, 2010 | 12:57 PM
phee's Avatar
I got the Shifts
it doenst have to slip to be gone. the fact that its banging gears shows that it has issues.
Old Jun 10, 2010 | 12:44 PM
TarzanCLS's Avatar
FIXED!!!!
car needed a new TPS sensor. excessive research, and talking to E30 and Paul led me to the TPS being a 20% possibility. didnt throw any kind of code until i unplugged the harness and re-connected it. got one off ebay, $30 shipped, then adjusted it with a voltmeter. 0.5v to 4.5v . car shifts like a champ and goes through every gear. im going to do another trans flush and filter as soon as the filter comes in from acura. almost cried when it hit me that i didnt need to blow 1k and a day on a trans swap
Old Jun 10, 2010 | 01:37 PM
DarkSithCL's Avatar
FIXED!!!!
...thats awesome news! ....I dropped almost 3 k on my last tranny, so I am def feeling ya!
Old Jun 10, 2010 | 03:32 PM
aznboi2424's Avatar
glad to hear you got it working great! props to the azine crew for troubleshooting the problem.
Old Jun 10, 2010 | 03:43 PM
Can't beat a $30 fix.
Glad to hear the car is longer down.
Old Jun 10, 2010 | 06:12 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i'll keep that in mind about the tps sensor.... what a wonky lil bugger
Old Jun 11, 2010 | 10:25 AM
PANAMARED's Avatar
really happy for you! i was sure it was a sensor, have not heard any of us yet with blown tranny and not slipping gears
Old Jun 16, 2010 | 12:48 AM
TarzanCLS's Avatar
can anyone tell me exactly what the book says for the volts of the TPS? ive read so many different variations from 0.45, 0.475, 0.49, 0.50, etc for closed throttle. what the hell is the correct spec? thanks!
Old Jun 16, 2010 | 12:54 AM
civicdrivr's Avatar
As close to .5v as you can get it at closed throttle and IIRC 4.5v at WOT.
Old Jun 16, 2010 | 12:58 AM
TarzanCLS's Avatar
thanks! thats what i have it at, but i was just reading so many different numbers, i wanted to be sure. should i reset the ecu and do idle learn as well?
Old Jun 16, 2010 | 12:59 AM
civicdrivr's Avatar
You shouldnt have to.
Old Jun 16, 2010 | 01:01 AM
TarzanCLS's Avatar
thanks again! f that s for automatic, i need a 6spd
Old Jan 22, 2012 | 12:33 PM
Brian Alda's Avatar
Having same issues with 2001 cl-s But all guages, windows, wipers work, lights work but reverse lights dont. I sometimes cant get it out of park and then it wont go out of first. I like the TPS for the trans problem but that wouldn't make the guages go out would it. This all started last night. help!!!
Old Jan 22, 2012 | 12:49 PM
Brian Alda's Avatar
I meant Windows,wipers, reverse lights, guages and sun roof do NOT work
Old Jan 24, 2012 | 04:24 PM
aznboi2424's Avatar
Check the driver's side fuses yet?
Old Feb 7, 2012 | 06:43 PM
andrewl01's Avatar
6th Gear
My tranny (01 CL-S) popped about 4 years ago and had to replace it (thank fully under warranty) but it JUST started to get glitchy again! I'll keep in mind the TPS...hopefully I won't need to blow 6k (yes...$6000 here in Canada to get a remade tranny...)
I'm researching on how (and how difficult it is) to do an engine swap with the 08 TL-S with manual.
Auto trannies are too fussy!
Old Feb 7, 2012 | 06:44 PM
p.diddy's Avatar
https://acurazine.com/forums/2g-cl-problems-fixes-70/another-solution-my-auto-cl-guys-758220/
SidhuSaaB
May 30, 2020 12:40 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Popee
Dec 20, 2015 12:08 AM
LeVeL
Oct 18, 2015 04:19 PM
Hines57
Sep 24, 2015 01:58 PM
