Help: Enginer revving up and down at P
Old Apr 6, 2012 | 11:26 PM
alexcls02's Avatar
Hey guys,
I went to take out my 3.2 CL T-S today, after 2 years of not using it (last time I turned it on was 6 months ago to start the engine and drive a bit).
The problem:
- When sitting in Park, the car revs up and down. As simple as that. Here is a video of the same
What should I be looking at and how much should I expect to pay to fix this?
Old Apr 7, 2012 | 10:38 AM
fuzzy02CLS's Avatar
Vacumn leak
Bad IAC
Dirty throttle body
Low batter voltage
Bad gas
Could be any of those
What happens if you go out & stomp on the gas WOT a few times?
Old Apr 7, 2012 | 11:45 AM
alexcls02's Avatar
Originally Posted by fuzzy02CLS
Vacumn leak
Bad IAC
Dirty throttle body
Low batter voltage
Bad gas
Sorry for the newb question, what is WOT? Wide open throttle, full throttle?
It could be the low battery voltage because it has sat for over 6 months and before that it sat for a good year without use. I probably should just buy a new battery right?
Old Apr 7, 2012 | 01:17 PM
civicdrivr's Avatar
Its not the battery if the revs are fluctuating above 800rpms. If the charging system had an issue, it would have very low RPMs.
Its most likely a clogged IACV.
Old Apr 7, 2012 | 07:40 PM
alexcls02's Avatar
Thanks guys, I took it to Autoparts and had them read the computer. It gave an EGV error (not sure what that is?)
Anyway, went to change the oil and had the tech said he cleaned the intake and reset the light. Told me to put premium gas and to drive the car for a week.
Drove it all day, no issues. So for now, all is good.
Not sure what it could have been. What is IACV (Intake air control valve?)
Old Apr 7, 2012 | 08:21 PM
civicdrivr's Avatar
You do use premium gas all the time, right?
IACV is a valve on the throttle body that regulates the air that travels through a small port when the throttle body is closed.
If the car were at idle and you turned the a/c on, the valve opens to compensate for the extra drag on the engine.
Old Apr 7, 2012 | 08:30 PM
alexcls02's Avatar
Thanks man, yes, I do use premium all the time.
So I guess that is what the mechanic cleaned and now it's working well. I'll keep you guys updated in case anything unexpected happens.
Do you recommend anything else?
Old Apr 10, 2012 | 02:39 PM
aznboi2424's Avatar
Is this a 1G CL? Gauge cluster is not from a 2G CL
Old Apr 10, 2012 | 02:49 PM
alexcls02's Avatar
Gen 2, 2002
Old Apr 10, 2012 | 03:59 PM
aznboi2424's Avatar
Originally Posted by alexcls02
Gen 2, 2002
So it doesn't look like this?
Morgan, help?
Old Apr 10, 2012 | 05:16 PM
alexcls02's Avatar
Morgan, help?
It looks exactly like that, I posted a video example of a guy with a civic with the same problem
Old Apr 10, 2012 | 05:33 PM
aznboi2424's Avatar
Oh, I thought something didn't add up lol reading fail
Old Apr 10, 2012 | 11:27 PM
civicdrivr's Avatar
I was about to post the same thing when I first saw the thread, but I reread the post again.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
