Foggy head lights cover
Old Jun 11, 2009 | 11:49 PM
arp408's Avatar
is there any place i can take my car to clean it? Or is it had to open it up and to clean it? Thanks
Old Jun 12, 2009 | 12:03 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Is it on the inside or outside?
Old Jun 12, 2009 | 12:05 AM
arp408's Avatar
inside. i already cleaned the outside and that's not the case.
Old Jun 12, 2009 | 12:10 AM
If its the inside you will want to split them open and do it yourself because a shop that would atempt this for you probally has never even did it before and would kill you on labor.Do you know how to open our lights?
Old Jun 12, 2009 | 12:41 AM
arp408's Avatar
ohh ok. i don't know..... is it difficult?
Old Jun 12, 2009 | 01:06 AM
not really.depends how well you know your way around cars,and how much ability you have.I've modified my lights twice.And wetsanded buffedand polished to like new.
have any questions or need any help let me know..
Old Jun 12, 2009 | 02:23 AM
Mac424's Avatar
here is a really good DIY on how to open your headlights
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/d-i-y-clearing-headlights-495390/
i need to do the same thing just haven't got around to it yet
Old Jun 12, 2009 | 10:22 AM
arp408's Avatar
richardparker
Your head lights are nice!!!!!!!!! I wanna do that!
Old Jun 12, 2009 | 12:02 PM
NSXNEXT's Avatar
If you're talking about moisture in the lights, before you take them apart you might want to try a quick fix to see if it solves the problem.
Remove the HID bulb only and find one of those silica salt packets (the things you find in boxes to control moisture.
Get a few of them, attach a string to them, and pop them into the headlight case. Give it a day or so and it should clear up the moisture. Then put the HID bulb back. Check all the other bulbs to make sure they're seated properly (remove and reinstall). Give it a week or so to see if the moisture comes back.
Old Jun 12, 2009 | 12:08 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You may want to try wetsanding them or getting a $20 headlight restoration kit before you go and crack open your headlights
Old Jun 12, 2009 | 12:23 PM
civicdrivr's Avatar
1600 grit sand paper + bucket of water + meguiars plastx + time = clean headlights.
Old Jun 12, 2009 | 12:39 PM
fekabeka's Avatar
I had a same problem! If you still have warranty on you car let the shop to do it.
Old Jun 12, 2009 | 07:14 PM
arp408's Avatar
It's more of dirt than moist. I have to glue it back in though right?
Old Jun 12, 2009 | 07:48 PM
If its more dirt then moisture then most likely its on the out side.Put your finger on the spot and look down from the top you will be able to tell if its on the inside or out side.If you find it to be on the inside try the silica packets like NSX said before attemping opening your lamps.If its on the out side they need to be wet sanded 600-1000-2000 then buffed with light compound(not cutting compound)Then hand polish with plasti-x.And hand wax With your fav stuff.I used spray wax.And to keep them looking good,dont clear coat,just rewax once or twice a month depending on how dirty your car gets and you'll be fine.
Old Jun 12, 2009 | 08:01 PM
arp408's Avatar
I'll try that. But I'll take a picture of it when i get a chance to. Thanks guys!
Old Jun 12, 2009 | 08:07 PM
arp408's Avatar
richardparker
are you from the bay area by any chance?
Old Jun 12, 2009 | 08:10 PM
arp408's Avatar
This is used the clean the outside lense of your head light right?
Old Jun 12, 2009 | 08:18 PM
civicdrivr's Avatar
Yea, theres a DIY in the FAQ section. I followed it, it makes your car look new again
Old Jun 12, 2009 | 08:26 PM
richardparker
from mass,but currently stuck in bum f!@# north carolina Sorry
Old Jun 12, 2009 | 09:48 PM
arp408's Avatar
is there alot of asian cars there?
Old Jun 12, 2009 | 10:04 PM
I've seen more in Boston then I do here.
Old Jun 12, 2009 | 10:16 PM
civicdrivr's Avatar
Feb 25, 2020 09:57 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
