DIY for transmission replacement?
Old Jun 29, 2009 | 11:32 PM
thevikas87's Avatar
Your mom is in
I hope I don't jinx myself when I ask this question, but is there a DIY for the replacement of an automatic transmission with just another auto transmission?
I tried searching but didn't come up with anything viable. Thanks.
Old Jun 30, 2009 | 09:31 AM
Rajca's Avatar
wham bam thank you ma'am
U serious? U need tools that u will probably never use again. Or have friends that do these kind of jobs. It u need a diy for replacing a trans u should do it. Its not like putting on a cai or headers. Lots of time is involved and its a critical part if u were to install it wrong things can go bad on the road and hurt ppl. Leave it to the professionals
Old Jun 30, 2009 | 09:54 AM
phee's Avatar
I got the Shifts
drain fluid
remove axles
remove bolts fromt trans
remove trans
replace trans
Old Jun 30, 2009 | 09:56 AM
andrew070489's Avatar
^ that doesnt sound too bad.. once removing the mounts and unbolted the tranny just lower it with a jack or 2?
Old Jun 30, 2009 | 10:21 AM
Pseudomaniac's Avatar
He left out dropping the subframe off the front of the car to accomplish the whole removal and reinstallation piece....
Old Jun 30, 2009 | 10:39 AM
civicdrivr's Avatar
And disconnecting the shifter and all electrical connectors.
Old Jun 30, 2009 | 11:45 AM
thevikas87's Avatar
Your mom is in
Yes. I am SERIOUS.
I have friends that are qualified to do this, but I would like to get the details before we are ever to attempt this sort of thing.
I understand it is not simple and lots of time is involved, thus I am seeking advice/tips/info on here...
Old Jun 30, 2009 | 12:12 PM
AnthraciteBeast's Avatar
I can scan the procedure out to the SM if you want
Old Jun 30, 2009 | 12:14 PM
Rajca's Avatar
Ur gonna need a lift. When I swaped engines in my tl-p. I did it from the top with the trans attatched. A lot harder and u have to be more cautious of the space around the engine. But it worked. Do what phee said and disconnect all electricall connections and hydraulic connections. Take off hood. Use a cherry picker to pull out engine. Do it slowly and have friends on each side of the engine looking for anything that is connected. Also unbolt the down pipe. Ur gonna have to angle the engine to get it out.
Old Jun 30, 2009 | 12:19 PM
thevikas87's Avatar
Your mom is in
That would be awesome and very helpful, thank you.
I understand why theres all the talk and DIY for 6 speed swaps, but with the number of auto trannies that have gone out over the years, one would imagine there would be a DIY or thread about swapping in another auto transmission....
Old Jun 30, 2009 | 12:21 PM
thevikas87's Avatar
Your mom is in
So you just pulled out the entire Engine + Trans, then did everything while all of it was out of the car?
When Acura replaces the transmission, is this how they do it?
Old Jun 30, 2009 | 12:30 PM
Rajca's Avatar
I pulled it out of my parts car and put it in through the top since I didn't have a lift. I had an acura tech ffiend help me. They drop the subframe I believe
Old Jun 30, 2009 | 01:28 PM
fsttyms1's Avatar
The trans will drop out of the bottom of the car. WARNING its very very heavy (one of the heaviest trans i have ever handled) You need to remove the radius rods and the front subframe the bolts that connect the flex plate to the tq converter and the bolts to the motor, axles and it will come out the bottom. If you have an engine hoist to lower the motor to the floor its a fairly easy job. My first time ever swapping in the garage (without the help of a manual) was a 6 hr job start to finish taking dinner and beer breaks
Old Jun 30, 2009 | 01:33 PM
thevikas87's Avatar
Your mom is in
We have just about every tool imaginable to work on a car, if this were to be done, it would be in their body shop, they have a lift also.
Old Jun 30, 2009 | 01:44 PM
I'll scan and post later tonight
Old Jun 30, 2009 | 02:40 PM
Lift, trans jack, and a couple extra pair of hands - you'll be okay. Watch all the funky connectors - they use the top of that trans like a junction box. Colored zip ties / twisty ties FTW. You should probably consider replacing the trans mount while you're at it - they're prone to wear out at 150k+.
Old Jun 30, 2009 | 04:19 PM
yea thats what i would have thought
Old Jun 30, 2009 | 05:00 PM
Rajca's Avatar
Bc it was all under warrenty limits before.
Old Jun 30, 2009 | 07:41 PM
thevikas87's Avatar
Your mom is in
Yea, that could be one of the possible reasons...
Either way, the site needs one. It'll be a good addition.
Old Jun 30, 2009 | 09:59 PM
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
bnaritomi
Feb 17, 2016 03:22 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
gqdabien
Sep 8, 2015 11:41 PM
