Check engine time
Waits for Shakira in his
Check engine time
When I start my cl the check engine light flashes about 10 time then it goes away. I kno this is bad but what should i do or what could be the problem
3.5 psi
Is is check engine or maintenance required? For the mainenance, you hold the two buttons to the right of your gauges and turn the key to the on position, keep holding for like 10 seconds and it resets.
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
My light flashes 3 -4 times I think, It always does that..
well I think its been doing it for the 9 years I owned the car, as long as it don't stay on you are ok.. I think its like checking itself!
B A N N E D
I dont think that it cuz i changed my oil 1k miles ago and it still always flashes I dont think that that is it!
B A N N E D
I always change my own oil now and never reset it. So right when u start the car the maint required light is not even suppose to flash a few times and stay off?
Well it does it in intervals.
At first it does that (flashes a few times, turns off) as a friendly reminder and then if more time lapses...
It will flash more and then just stay on until it's reset...basically as a constant reminder to change your oil.
Whats up with RDX owners?
As soon as youre 250 miles past the reccomended change interval, it will turn to solid.
Mike Bertram
09-10-2015 09:27 AM
