Check engine time
Old Jun 17, 2009 | 03:33 PM
madmuzik09's Avatar
Waits for Shakira in his
Check engine time
When I start my cl the check engine light flashes about 10 time then it goes away. I kno this is bad but what should i do or what could be the problem
Old Jun 17, 2009 | 03:34 PM
gnuts's Avatar
3.5 psi
means you're due for oil, that's it. Reset it or ignore it.
Old Jun 17, 2009 | 03:43 PM
madmuzik09's Avatar
thats all Cuz im planning on changing the oil tomorrow but how do i reset the light
Old Jun 17, 2009 | 03:52 PM
gnuts's Avatar
3.5 psi
Is is check engine or maintenance required? For the mainenance, you hold the two buttons to the right of your gauges and turn the key to the on position, keep holding for like 10 seconds and it resets.
Old Jun 17, 2009 | 03:55 PM
madmuzik09's Avatar
Oops i meant the maintenance required light flashes 10 times does this change the prob cuz i still need a oil change
Old Jun 17, 2009 | 03:56 PM
thevikas87's Avatar
Your mom is in
maintenance required light can be turned off, by holding down the select and reset buttons before starting the car, as you are holding them down, start the car and continue to hold them until the light goes off...
Old Jun 17, 2009 | 03:58 PM
madmuzik09's Avatar
the light doesnt stay on though it flashes 10 times and then goes away
Old Jun 17, 2009 | 04:10 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
My light flashes 3 -4 times I think, It always does that..
well I think its been doing it for the 9 years I owned the car, as long as it don't stay on you are ok.. I think its like checking itself!
Old Jun 17, 2009 | 05:12 PM
aznboi2424's Avatar
it flashes between 6001 and 7499 miles. it will stay on solid after 7500 since the last reset. its a reminder to change the oil. the flashing part of the interval is just like a reminder to make an appointment with the dealer soon or something.
Old Jun 17, 2009 | 05:19 PM
StonedCL's Avatar
B A N N E D
I dont think that it cuz i changed my oil 1k miles ago and it still always flashes I dont think that that is it!
Old Jun 17, 2009 | 05:38 PM
aznboi2424's Avatar
thats cause you'll have to manually reset the light yourself. its only mileage based, not a oil life monitor like on the newer acuras
Old Jun 17, 2009 | 07:37 PM
nf3d0149ab's Avatar
Exactly...Just reset it because who ever changed your oil last time never did...
It's in the owner's manual and under the FAQ's.
/thread
Old Jun 17, 2009 | 07:54 PM
aznboi2424's Avatar
noah, nominate me for new 2G CL moderator
Old Jun 17, 2009 | 07:57 PM
nf3d0149ab's Avatar
Okay...you're nominated.
Old Jun 17, 2009 | 08:05 PM
aznboi2424's Avatar
yes! thats 1 vote, i just need 999,999,999,999 more to go
Old Jun 17, 2009 | 08:10 PM
StonedCL's Avatar
B A N N E D
I always change my own oil now and never reset it. So right when u start the car the maint required light is not even suppose to flash a few times and stay off?
Old Jun 17, 2009 | 08:21 PM
nf3d0149ab's Avatar
Well it does it in intervals.
At first it does that (flashes a few times, turns off) as a friendly reminder and then if more time lapses...
It will flash more and then just stay on until it's reset...basically as a constant reminder to change your oil.
Old Jun 17, 2009 | 08:40 PM
aznboi2424's Avatar
yup, so i would reset it when i starts to flash.
Old Jun 18, 2009 | 11:42 AM
civicdrivr's Avatar
As soon as youre 250 miles past the reccomended change interval, it will turn to solid.
Old Jun 18, 2009 | 11:13 PM
OperationDarkie's Avatar
Ultra Negro
IMO stoned, put the weed down, hold the two buttons and start your car, then you wont have to ask the same question 5 or more times.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
