Car wont start
Old Jul 6, 2012 | 08:26 PM
thefam11's Avatar
Car wont start
During the hot weather my car just wont start. Ill drive about 20 miles to work then park my car in a scorching parking lot for 8 hours. When its time to leave, the car just wont start. You can hear it trying to turn over but just wont turn all the way over (if that makes sense). I can wait about 30 minutes and it will start up no problem at all. Does anyone have any clue of whats going on? Please help.
Old Jul 6, 2012 | 11:25 PM
CL-Future's Avatar
Lives in Boost
Sounds like your main fuel relay needs to be replaced. Do a quick search and you should see plenty of threads regarding this problem. Should be an easy fix...
Old Jul 7, 2012 | 11:41 AM
thefam11's Avatar
I just pulled the relay and all the soldering points look good to me. Dont know what else it could be.
Old Jul 7, 2012 | 01:09 PM
YeuEmMaiMai's Avatar
resolder it and install. If it works, great, if not, your other choice is Fuel Pressure Regulator and that isn't so cheap....
Old Jul 7, 2012 | 06:18 PM
CL-Future's Avatar
Lives in Boost
What he said. The solder points can look good, really like new, but still be faulty.
Old Jul 7, 2012 | 06:48 PM
thefam11's Avatar
I didnt feel like soldering today. Its 103 out and inside a car is not my favorite. Went to honda and got a new relay, its about an inch bigger but still works. Hopefully this will work.
Old Jul 7, 2012 | 07:34 PM
CL-Future's Avatar
Lives in Boost
Cool, I think they changed the design because of this issue but never really said anything about it. Hold onto the old one and solder it when you have a chance so you have a backup.
Old Jul 26, 2012 | 01:42 PM
xtrmnop's Avatar
Was your issue fixed by changing the main fuel relay? I've had this issue a couple of times. Not necessarily on a hot day but I wasn't able to start it at all during one hot day in San Diego. I came back home 4 hours later and the car started up just fine. It definitely sounds like a fuel issue. I'm wondering if I need to change the fuel filter.
Old Jul 26, 2012 | 01:50 PM
kaza's Avatar
more than likely you are experiencing the same issue. I would repair/replace your main relay first as it is a very common issue. Tip - Often hitting it will make it work temporarily.
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
