Car won't start!!
Car won't start!!
So the other day I leave for work, I get the maintenance required light flashing, no big deal, I drive to work and everything's fine. I get the light flashing again when I leave, disregard it, then go to a friend's house. I go to start the car, it starts ok, but then the engine is reving up and down and i hear a clicking noise coming from the gear shifter. I shut the car off and haven't been able to start it since. I've searched the site and found lots of info regarding a bad main relay, but in those cases the car would at least turn over. The battery seems fine as all my electrical works well, lights aren't dim, radio and fan come on. Any ideas>?
You did mention - revving up and down -does it happen only when the car is in Park ? - if yes looks like a sign of IAC valve is either dirty or defective. (thats $80 part ) and its located under the throttle body. As for bad main relay - that usually happens if you have crank no start issues - and most of the time it happens in a hot days summer days. This is a known issue for some hondas and acuras. Main relay - cost $30-$70 and its located under the steering colum left side. You can save money by getting the part outside the dealership.
The revving up and down only happened the one time right after I started it. I shut it off after about 10 seconds and haven't been able to start it since. It was in park when that happened, haven't had a chance to see if that happens while in drive or neutral because I can't start it now. I got the ! Light and the vsa light too, but no CEL so will there even be a code to read? Thanks for the help
bearingman07936
01-07-2016 03:22 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
