Car won't start
Old Dec 29, 2008 | 12:01 PM
Azrael's Avatar
Car won't start
Greetings,
First time posting, so I hope I'm doing this right!
Problem: 2001 ACURA CL Type S, 220k miles. Car doesn't start. Battery is 6 months old and is giving me 12.8 on voltmeter. I can hear the fuel pump engage when I turn the key and attempt to start it and nothing. I tried the fuel pump relay tapping trick, but like I said I can hear the fuel pump priming. Car has no modifications and has been running fine until yesterday (last time it started). Made sure immobolizer light went out upon placing the key in the on position and nothing else was next to the steering column.
Old Dec 29, 2008 | 03:20 PM
celynka's Avatar
Sundance Gold in
does it crank? Did you change your timing belt?
Old Dec 31, 2008 | 02:23 AM
YeuEmMaiMai's Avatar
check your starter relay. if it checks out tap your starter with a hammer, if the car starts, replace starter.
Old Dec 31, 2008 | 02:32 AM
2K1CLtypeS's Avatar
The brushes in the starter are hanging up because they are worn. Happened to me a few months ago. Rapped on my starter to get the brushes to re-contact the starter's armature. Replaced the starter and all's well again.....
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
