StreetKA's CLS6 Thread
Old 03-22-2011, 07:03 PM
  #281
StreetKA's Avatar
here is interior pic dont mind iphone quality...
i think it looks good but im not 100% satisfied with outcome...
installed also MAF oil catch can and ETD stiffy
not sure if its hooked up properly if its not then let me know ;p
still need to wrap the shifter
im still waiting for XLR8 mounts its kinda stupid to install ETD without mounts but i had to do something because i can not drive a car with engine mounts like this
Old 03-22-2011, 07:13 PM
  #282
3.7L Nitrous Breathing CL
richardparker's Avatar
Liking the console woods.
Are you doing the panel woods too ?
I would do the whole dash bezel from the pics that stuff looks like it comes out nice.
I never saw any in person before.
Old 03-22-2011, 07:27 PM
  #283
Jacobpockros's Avatar
Originally Posted by StreetKA
Dude! That looks badass!
You know what you should do next? It involves that wrap, and your intake
Old 03-22-2011, 07:47 PM
  #284
B A N N E D
friesm2000's Avatar
normally the PCV is on the back valve cover and not the front one....
along with the catch can hooking into the rear port, which is the one that normally allows the oil into the manifold; the "front" one just allows freash air into the crankcase (but a little seepage does occur, but minimal though, and mainly only happens when you shut a hot motor off, when those oil vapors go up that tube, and just kinda collects near the inlet in the intake
also is that the house expanding foam stuff i see on that mount lol
Old 03-22-2011, 07:59 PM
  #285
StreetKA's Avatar
i was thinking about it but i think i will just paint it black. thanks
does it make it different ? size of the hoses allowed me to do it only this was since the front port is a bit bigger and rear one is smaller diameter
it was cheap homedepot poly urethan that i pured into a front mount and let it dry for three weeks and after two days it came out of it...
as of ETD i love this thing already! car feels like a rocket during the shifts
Old 03-22-2011, 08:13 PM
  #286
B A N N E D
friesm2000's Avatar
kinda does, because 99% of the oil gets into the manifold through that back port
lol, just looks like that expanding foam shit
as far as the stiffy, yeah it makes quite a bit of difference, but with a good clutch still not enough though (mine is the hardest it will go ) (it was more then enough for the auto though, but then again i only drove on it for a couple of months with the auto still in)
Old 03-22-2011, 08:17 PM
  #287
StreetKA's Avatar
i just cant imagine how it could make a differance ? front or back...(no homo) i will change it but its same pipe just port on the other side its same vacuum on both sides
Old 03-22-2011, 08:33 PM
  #288
StreetKA's Avatar
my battery died on me again today where is the best place to buy braille battery (the cheapest place) im thinking about red/yellow top battery just dont know
which braille should be good for our car ?
Old 03-22-2011, 08:45 PM
  #289
B A N N E D
friesm2000's Avatar
both sides should not be under vacuum, the rear hose when connected to the manifold should have the vaccum, which then when you connect it to the rear valve cover, will allow that vacuum to get to the crankcase, which then means that front valve cover will get vacuum now, which then draws fresh air through the intake (before the throttle body)
btw the PCV is a metered orifice for the vacuum to flow through (so yes if you plug that hose on the front it will build the same amount of vacuum, because air is not being allowed to flow in as per the design)
costco i know has the optima normally
and as far as the braille battery, will the car stay a daily driver? especially during the winter? cause i know their performance/charge does drop off faster then a normal battery when it starts getting really cold out
might even look into a group 51 battery like the civic/rsx/crv has, it about half the size of the stock battery (which considering how cold it gets there possibly in jersey may still not be enough on those cold days IDK)
Old 03-22-2011, 08:52 PM
  #290
StreetKA's Avatar
saving 20-25lbs for 150$ is a great opportunity since i have to change the battery anyway...
they are 475 CCA and 640 CA
http://www.braillebattery.com/index....teries/b2317/#
but i see the mounting may be different
Old 03-22-2011, 09:21 PM
  #291
B A N N E D
friesm2000's Avatar
I am thinking more of durability and the group 51 batteryis normally in the 26 lb range iirc,so yes lighter then stock
BTW interstate batteries last like an average of like 5-7 years if not more here, so hard to complain about the durability of the lead acid battery
Old 03-23-2011, 06:37 AM
  #292
StreetKA's Avatar
Oddysey pc680 or Braille b2317 ? Anyone got experience with any of them on the east coast ?
Old 03-23-2011, 02:21 PM
  #293
How come your selling 03' tails?
Old 03-23-2011, 03:27 PM
  #294
StreetKA's Avatar
It was actually cracked on the top edge for a long time and was leaking water then it starts to become darker. I didn't like it. Then i decided to buy a tint spray and tint the red part of it. I wanted to clean it first with paint thinner and it cracked like crazy while i was looking at it. I saw a thread in BM localy and picked up new set. This one im selling because i simply dont need two pairs, still someone can use it but i didnt like the way it looked.
Old 03-23-2011, 09:12 PM
  #295
StreetKA's Avatar
i found out that Braille battery its just rebadged DEKA battery and its basicly the same for 3 times less... i want something lightweight... someone bear with me please
Deka $50-$70
Braille $150-$180
Oddysey $90-$150
DEKA spec sheet
http://www.anrdoezrs.net/click-31935...ase%2F0278.pdf
its same battery but spec say that Braille has 426CCA instead of 270CCA for a DEKA same manufacture looks same
http://www.lotustalk.com/forums/f321...-2015-a-78540/
http://www.lotustalk.com/forums/f321...1/#post1142265
Old 03-24-2011, 07:55 PM
  #296
StreetKA's Avatar
Picked up new car. I couldn't pass on this deal.
'03 Volvo S60 2.4 AT with 34k miles black leather interior
Old 03-24-2011, 08:00 PM
  #297
SimonCL-S6's Avatar
At?!
Old 03-24-2011, 08:08 PM
  #298
StreetKA's Avatar
yes... its for me and my girlfriend mostlikely still gotta CL and im gonna use it for trips to NYC
Old 03-24-2011, 08:10 PM
  #299
Nice pickup! That makes 2 Acura/Volvo drivers lol
Except yours won't break every other week
Old 03-24-2011, 08:19 PM
  #300
StreetKA's Avatar
im still looking for some kinda forum to find more info about this car... any help would be appreciated
Old 03-24-2011, 08:47 PM
  #301
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,159 Likes on 4,818 Posts
volvoforums.com ?
Old 03-24-2011, 09:30 PM
  #302
StreetKA's Avatar
i did post there but i see there wont be many responses
Old 03-24-2011, 09:37 PM
  #303
I use turbobricks.com for my volvo. It has the same layout as AcuraZine and it's a bit more active as far as replies go. Let me check to see if there is a section for S60's....
Old 03-25-2011, 12:36 PM
  #304
civicdrivr's Avatar
I thought TurboBricks died awhile ago. Its nice to see its still active.
Old 03-25-2011, 02:16 PM
  #305
It's the most active volvo forum out there. They don't have S60's though.... I guess that's because there not old enough to be bricks
Old 03-29-2011, 06:42 PM
  #306
StreetKA's Avatar
updated interior pics
Old 03-29-2011, 07:00 PM
  #307
WOW that looks rad. Now all you need is a carbon fiber shift knob and your all set!
Old 03-29-2011, 07:11 PM
  #308
StreetKA's Avatar
There is no way i will wrap shift knob. It perfect how it is with wraped knob would be too much.
Old 03-29-2011, 08:01 PM
  #309
6mt swapped..smart
AnthraciteTypeS's Avatar
It's already kinda too much imo, but if you like it that's all that matters. I would have left some of the brushed faux aluminum unwrapped for some contrast. Looks too dark
Old 03-29-2011, 08:12 PM
  #310
StreetKA's Avatar
looks better in person and day light
Old 03-29-2011, 08:46 PM
  #311
Regional Coordinator (Texas)
nspec_ya4's Avatar
definitely like it!
Old 03-29-2011, 09:32 PM
  #312
zac
zac's Avatar
Originally Posted by nspec_ya4
definitely like it!
+1
Old 03-29-2011, 09:34 PM
  #313
nspec_ya4's Avatar
u need RSX seats
Old 03-29-2011, 09:40 PM
  #314
zac
zac's Avatar
...and an RSX steering wheel. (I just realized a couple weeks ago, after owning the CL for 3 years, how huge the stock steering wheel is)
edit: didnt realize you have an MDX steering wheel, how does the circumference compare to the stock CL?
Old 03-30-2011, 07:49 AM
  #315
joyfil2001's Avatar
I think it looks great. I have my center console trim and shift plate wrapped as well. Looks way better in person. I'm really thinking about the steering wheel now.
Old 03-30-2011, 08:54 AM
  #316
StreetKA's Avatar
u need RSX seats
Dont wanna spend that much on car now.
I think i like Stock steering wheel. For me RSX doesnt look right in the CL interior but when u swap the rsx seats to its okay.
I think you should hold up a litle because its been a week since wraped it. And im not sure how it will react on the heat in the summer. its tough to wrap the wheel you have to strech it alot. Im affraid it will come off. Di Noc is also slippery and i dont think you want that on the steering wheel.
Old 03-31-2011, 04:22 PM
  #317
StreetKA's Avatar
ordered helms manual
parts for timing belt service also new slave cylinder, ss clutch line and P2R TB spacer
so lets correct me if im wrong
timing belt
tensioner pulley
water pump
timing idler
valve cover gasket ? are the front and rear the same ?
power steering fluid
coolant fluid
spark plugs and accessory belt are changed recently termostat is new too
what else ?
i want to do valve adjustment too
one question do you have to remove spark plugs to do valve adjustment ?
Old 03-31-2011, 05:03 PM
  #318
Received 1,748 Likes on 1,402 Posts
You don't have to; however, it makes turning the motor over, by socket wrench, to find each cylinders TDC a little easier.
Old 03-31-2011, 07:48 PM
  #319
StreetKA's Avatar
looks like im gonna need both axles replaced too what place do you guys recommend ?
autozone ? ebay ?
Old 03-31-2011, 09:06 PM
  #320
anthracitecl's Avatar
I think Autozone axles are lifetime warranty. I got mine from Advanced auto parts. They seems ok.
When I did my TB job, I also replaced auto tensioner and crank seal and cam seals. I didn't have to replace cam seals, but I knew it's gonna bugging me if I don't replace them. just picky
I like carbonfiber look!
Quick Reply: StreetKA's CLS6 Thread
