StreetKA's CLS6 Thread
Old 09-07-2011, 11:24 AM
  #681
SimonCL-S6's Avatar
Originally Posted by Jacobpockros
Paint looks nice but it might look shinier if it had low miles
Hows the used supercharger install going? Your car should sound nice when it's done.
Its a daily driver not a bugatti
Old 09-07-2011, 01:25 PM
  #682
anthracitecl's Avatar
So what method did you use for mounting pvc pipe on apillar? If you don't mind me ask..
Old 09-07-2011, 07:33 PM
  #683
NM. I got it.
Old 09-07-2011, 07:48 PM
  #684
StreetKA's Avatar
^ yup previous page says most of it but i will pm you later with details.
Old 09-08-2011, 09:09 PM
  #685
StreetKA's Avatar
ok so i finally installed wideband but i notice that car is running a bit rich at wot around 5200-5800 and im not sure why is like that maybe injectors arent in the best shape ?
http://www.youtube.com/watch?v=V21NehH_aHY
replaced also front swaybar links and bushings
my upper balljoints are shot but im getting installed adjustable arms tomorrow so it will be replaced
next week im getting RR bushings done as well
Old 09-08-2011, 10:06 PM
  #686
StreetKA's Avatar
what about this cat ?
http://cgi.ebay.com/ebaymotors/94109...#ht_2543wt_939
Old 09-09-2011, 04:59 AM
  #687
wham bam thank you ma'am
Rajca's Avatar
its running fine
Old 09-09-2011, 07:38 AM
  #688
03 acura cl type s
rush's Avatar
Our cars are tuned that way
Old 09-09-2011, 07:41 AM
  #689
03 acura cl type s
rush's Avatar
Originally Posted by StreetKA
Don't waist your just run a straight pipe and a O2 sensor spacer & u can still pass inspection @ the DMV with no problem
Old 09-09-2011, 08:20 AM
  #690
StreetKA's Avatar
Originally Posted by Rajca
its running fine
I pulled the fuse to reset ECU now it doest go any lower than 12
I dont think it will pass inspection without cat how come you are so sure about that ? I dont want to smell gas all the time anyway.
Old 09-09-2011, 08:32 AM
  #691
p.diddy's Avatar
i forgot which fuse resets the ecu?
Old 09-09-2011, 08:52 AM
  #692
03 acura cl type s
rush's Avatar
Cause I have first hand experience with it and the cat your looking @ is different from ours. Our O2 goes in the cat not before or after.
This pic is from my old cl6 look closely wideband O2 and second O2 with vibrant spacer http://i1119.photobucket.com/albums/...h/dc0fe1df.jpg
Old 09-09-2011, 09:22 AM
  #693
StreetKA's Avatar
Fuse nr 13 on the passenger side 15A blue.
Old 09-09-2011, 09:24 AM
  #694
p.diddy's Avatar
thanks.
Old 09-09-2011, 10:33 AM
  #695
3.5 psi
gnuts's Avatar
you need to weld in a new bung for the wideband right? Near the stock primary? I need to grab an AEM wideband next.
Old 09-09-2011, 10:40 AM
  #696
StreetKA's Avatar
Yes. I placed mine right after flex pipe.
Old 09-09-2011, 11:30 AM
  #697
Jacobpockros's Avatar
http://cgi.ebay.com/ebaymotors/Carso...ht_1745wt_1167
Old 09-09-2011, 12:13 PM
  #698
StreetKA's Avatar
STAY AWAY from that seller i do NOT recommend buying anything from them. Poor customer service never get any response on my emails or calls. I sent back old resonator for exchange and i never got replacement nor money back. I had to open a case with ebay.
Old 09-10-2011, 05:18 PM
  #699
StreetKA's Avatar
Ingalls adjustable control arms installed - going to alignment next week with new set of Hankooks V12 235/40
i got set of RR bushings but its was too much pain to have it installed so it will wait till i get the rest of the parts and do the clutch first then change all of the parts i was planing to...
Old 09-10-2011, 05:48 PM
  #700
Received 1,827 Likes on 1,470 Posts
lol, it's alot of work for sure.
My power steering pump is starting to go after 126K, so I ordered all of the OEM seals and bearing for a rebuild. Looking forward to digging into this project. It will cost about $40 + or - compared to a $250 reman. unit.
Going to follow the link below as well as the Helms for the rebuild:
http://www.facebook.com/photo.php?fb...17b400&theater
StreetKA (09-10-2011)
Old 09-10-2011, 05:59 PM
  #701
StreetKA's Avatar
i know u did replace rr bushings did you removed axles to undo these bolts ?
thx for the link its good to have something just in case
you can make a DIY based on this one with all sources for seals bearings
Old 09-10-2011, 06:11 PM
  #702
No, it's not necessary. Loosen the self-lock nut (I believe it was 17mm) on the front of the RR first, while it's secured to the LCA. Separate the outer tie rod end, and lower ball joint. This will allow you to swing the whole knuckle assembly forward a bit along with the axle. You'll see what I mean when you are there. Make sure to support it (knuckle) with an extra jackstand or jack because you do'nt want that thing to drop on yourself. Get your 19mm on a breaker bar, push down on the LCA a bit, fit the socket and wrench away. Those two bolts are on at 116 lbs-ft or so, IIRC, so give them hell. hehe
Old 09-10-2011, 07:04 PM
  #703
StreetKA's Avatar
i was doing control arms today but i didnt feel like doing it anyway lol next time
Old 09-10-2011, 09:09 PM
  #704
StreetKA's Avatar
im looking forward to do RDX injectors soon i heard that j32a3 runners are direct fit for those injectors but what about fuel rails can we use j32a3 too ? please help i do not want mod RDX to j32a2 unless its easier to do so
Old 09-11-2011, 08:32 PM
  #705
StreetKA's Avatar
i need some help... since im doing most of the suspension work right now and i want to have piece of mind for a long time what should i replace ?
done is upper control arms with ball joins, swaybar links and bushings, tomorrow RR bushings,
lower ball joints looks ok but should i replace them anyway ?
Old 09-12-2011, 08:54 AM
  #706
3.5 psi
gnuts's Avatar
did you weld on a bung? i see some regular bungs and a 45* angled bung.
Old 09-12-2011, 11:19 AM
  #707
StreetKA's Avatar
I welded the bung that comes with aem gauge kit. But i know that there is a wideband kit that doesnt require welding. And it costs like 35$ you simply drill the hole and use their clamp to mount the sensor. If you want i can post a picture of a sensor welded but remember that it must be mounted exact angle
Old 09-13-2011, 07:12 AM
  #708
StreetKA's Avatar
Not the best weld but i didn't have access to TIG. For that litle room i think its not bad.
gnuts (09-13-2011)
Old 09-13-2011, 07:43 AM
  #709
03 acura cl type s
rush's Avatar
Corect me if I'm wrong but isn't the wideband surpose to be after the cat?
Old 09-13-2011, 08:36 AM
  #710
StreetKA's Avatar
I dont see a point of that. What if you dont have a cat ? If you're running testpipe ?
Old 09-13-2011, 08:52 AM
  #711
3.5 psi
gnuts's Avatar
no before the cat. you want direct numbers from the engine. not numbers filtered by the cat.
Old 09-13-2011, 09:00 AM
  #712
JBlueCLS6's Avatar
This is correct, I had it welded on the same spot
Also Gnuts, I know you're looking for an AEM Uego WideBand. PM me as I doubt I'll be hanging around these forums much longer.
Old 09-13-2011, 02:27 PM
  #713
3.7L Nitrous Breathing CL
richardparker's Avatar
How are your di noc interior pieces holding up ?
I am going to get some and I'm about to bite your interior wood wrapping if yours is still looking good.
Old 09-13-2011, 03:08 PM
  #714
StreetKA's Avatar
It's holding up surprisingly good. I love it.
richardparker (09-13-2011)
Old 09-13-2011, 03:14 PM
  #715
I just bought 36 x 48 sheet and a cf licence plate to replace the gold one.
36x48 should be enough ?
Jacobpockros (09-13-2011)
Old 09-13-2011, 03:59 PM
  #716
StreetKA's Avatar
I'm pretty sure this is the size i ordered
Old 09-14-2011, 06:23 PM
  #717
StreetKA's Avatar
ok so i did the alignment today and put new tires car finally drives like a dream
i also installed xlr8 sidemount that i totally forgot about... no reviews yet but im going tonight for a small car meet so will check them out :P
i can not find time though to do RR bushings, i just dont want to work on it in my garage, waiting for friend to let me use his lift at his shop
Old 09-14-2011, 06:48 PM
  #718
03 acura cl type s
rush's Avatar
WhAt meet ? I wanna come
Old 09-14-2011, 06:56 PM
  #719
StreetKA's Avatar
tonight toys r us Hazlet nj around 9-9.30 PM
Old 09-15-2011, 11:58 AM
  #720
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,394 Likes on 4,939 Posts
Let me know about any meets next week. Im heading to NY this Saturday or Sunday and staying until the following weekend.
Quick Reply: StreetKA's CLS6 Thread
