My Build Thread - bordering on more BS! 56K Beware
Old 01-17-2011, 06:19 PM
  #1081
StreetKA's Avatar
so thats what they call "pulling timing" ?
StreetKA is offline
Old 01-17-2011, 06:21 PM
  #1082
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,450 Likes on 4,972 Posts
And running very rich.
civicdrivr is offline
Old 01-17-2011, 06:32 PM
  #1083
aysertypes's Avatar
great work
aysertypes is offline
Old 01-17-2011, 06:38 PM
  #1084
civicdrivr's Avatar
Thanks.
Old 01-17-2011, 06:53 PM
  #1085
3.5 psi
gnuts's Avatar
so is that pre and post 80mm intake?
gnuts is offline
Old 01-17-2011, 07:22 PM
  #1086
B A N N E D
friesm2000's Avatar
Originally Posted by StreetKA
^let me explain why...
i could keep up with Morgan without hiting vtec so thats why i did only once
i was saving gas
you still had plenty of weaving room though (just gotta be able to squeeze in), so you could had hit VTEC alot more often
BTW we need some pics of this Polish Girl
(also what was that Ka from the V1 at 11:45 in the video, right before she talks)
friesm2000 is offline
Old 01-17-2011, 07:25 PM
  #1087
civicdrivr's Avatar
Yea, forgot to add that.
Old 01-17-2011, 07:30 PM
  #1088
BANNED
NVA-AV6's Avatar
I wish that dyno had AFR......
NVA-AV6 is offline
Old 01-17-2011, 08:04 PM
  #1089
civicdrivr's Avatar
Me too, but right around 6k you can see where it falls on its face. I cant wait to tune it.
I wish the graph showed what the peak torque number was too. Looks to be around 275 though.
  #1090
StreetKA's Avatar
no pics
it wasnt Ka it was a Laser false alarm from someones led tailights or bulbs
so it doesnt make sense to rev it past 6k now...
StreetKA is offline
Old 01-17-2011, 10:49 PM
  #1091
B A N N E D
friesm2000's Avatar
even mine does the same thing on the dyno, looks to fall flat at 6k, but on the street that where it seems to pull the most though
Old 01-17-2011, 10:51 PM
  #1092
B A N N E D
friesm2000's Avatar
no pics
and now that you mention it, it was indeed "laser" , maybe it's because i was on a POS mac computer when i watched it
Old 01-18-2011, 03:26 AM
  #1093
BANNED
NVA-AV6's Avatar
I am actually surprised by the 20+ WTQ gain, I expected the 20+ WHP gain, but figured you would eaither stay the same or even lose a couple TQ.
NVA-AV6 is offline
Old 01-18-2011, 09:51 AM
  #1094
BANNED
NVA-AV6's Avatar
3 to 1 merges done.....
Now waiting on the tight radius bends to make the turn onder the oil pan.
NVA-AV6 is offline
Old 01-18-2011, 09:55 AM
  #1095
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,982 Likes on 1,359 Posts
Impressive!
e30cabrio is offline
Old 01-18-2011, 10:04 AM
  #1096
nf3d0149ab's Avatar
Dayum!
nf3d0149ab is offline
Old 01-18-2011, 10:09 AM
  #1097
StreetKA's Avatar
Thats is sick ! Me want !
StreetKA is offline
Old 01-18-2011, 10:48 AM
  #1098
I Drive Like A Dick 8≈
Nersh7's Avatar
Jeeze thats sexy
Nersh7 is offline
Old 01-18-2011, 01:10 PM
  #1099
civicdrivr's Avatar
Cant wait to get them on.
Old 01-18-2011, 01:56 PM
  #1100
Your Friendly Canadian
Aman's Avatar
Received 1,491 Likes on 1,050 Posts
Aman is offline
Old 01-18-2011, 07:47 PM
  #1101
B A N N E D
friesm2000's Avatar
at first i saw the prototype, and was , with those bends, but the second set is MUCH BETTER though...
btw that's the WRONG mount, that's a 3g TL one, not ours...
Old 01-18-2011, 07:57 PM
  #1102
BANNED
NVA-AV6's Avatar
The first one is the rear and has to belike that to clear the rear mount casting and maintain the same leg legnth as the front. Yes the front mount is a 3rd gen but has the same clearence requrements as the 2nd gen front mount
NVA-AV6 is offline
Old 01-18-2011, 08:31 PM
  #1103
B A N N E D
friesm2000's Avatar
that is the rear
but with those sharp courners though... (where the welds are mid-pipe, look likes they get to the weld and the pipe just turns, and not a nice smooth bend)
as far as having bends there, not much you can do about it when you gotta go around other things
btw: on that front mount, is it the same "bolt" pattern as on the 2g, where it bolts to the crossmember...
Old 01-19-2011, 05:14 AM
  #1104
BANNED
NVA-AV6's Avatar
that is the rear
I know they look sever but they are made using bends not just cutting strights and welding them up so it does not affect flow.
As far as the front mount bolt patteren, they are the same on the block/tranny and really close on the cross member, a little work with a file and it bolts up.
NVA-AV6 is offline
Old 01-19-2011, 01:05 PM
  #1105
B A N N E D
friesm2000's Avatar
as said they still look very severe
and as far as the bolt pattern , another question how about the height of the mount as an assembly..., could i stick a 3g mount on a 2g, with only the filing of the holes?
Old 01-19-2011, 01:21 PM
  #1106
civicdrivr's Avatar
Second projector came in!! Im going to work on the retro tonight but Im not sure if I can finish before driving to NY tomorrow.
The car got new shoes today too. Ill post a pic later.
Old 01-19-2011, 01:57 PM
  #1107
BANNED
NVA-AV6's Avatar
You need both the mount and the casting that bolts to the engine/trans
NVA-AV6 is offline
Old 01-19-2011, 06:59 PM
  #1108
Your Garage
DC3328's Avatar
DC3328 is offline
Old 01-19-2011, 08:17 PM
  #1109
B A N N E D
friesm2000's Avatar
i have no worries about that, just that they would not need to be modified a whole lot if i wanted to fit one...
Old 01-20-2011, 12:19 AM
  #1110
B A N N E D
friesm2000's Avatar
and even then, how many set of those wheels are out there.... (being that they are a stock set of wheels)
Old 01-20-2011, 07:50 AM
  #1111
StreetKA's Avatar
I just want to know if my wheels fit. I think they should fit. Hows the plasti dip paint it will peel of with powwer wash or what ? I think it could peel of it self and then looks ugly.
StreetKA is offline
Old 01-20-2011, 07:58 AM
  #1112
Aman's Avatar
Never been a fan of those in black, but whatever you choose. What kind of finish does the plasti-dip give?
And holy shiz that is pretty close to the front calipers. GL cleaning that, man
Aman is offline
Old 01-20-2011, 08:00 AM
  #1113
BANNED
NVA-AV6's Avatar
Plastidip will give a finish like the rubber handle cover of a pair of pliers.
NVA-AV6 is offline
Old 02-03-2011, 05:14 PM
  #1114
civicdrivr's Avatar
Old 02-03-2011, 06:45 PM
  #1115
Aman's Avatar
Painted?
You seem to have this uncanny affection of all things black, don't you?
Aman is offline
Old 02-03-2011, 06:47 PM
  #1116
StreetKA's Avatar
cant be painted its just dark metal guess bc paint will wear out
StreetKA is offline
Old 02-03-2011, 07:00 PM
  #1117
Quarantuning
SlickShiftNall6's Avatar
Nice updates. Those pedals look so sick. If you painted those you did a great job. I'm guessing you did because you like to be different and everyone has the metal or silver pedals. Never seen em for sale like that. The TL wheels look good, I like the silver look on black. Yeah they are a close fit... Did you have to shave the end of the bolts down on your bracket so they would clear? Had too with mine.
SlickShiftNall6 is offline
Old 02-03-2011, 09:09 PM
  #1118
civicdrivr's Avatar
Originally Posted by Aman
Painted?
Anodized aluminum.
You know what they say, once you go black, you dont go back.
I just dont like really shiny things.
Yea, I had to trim down the studs so theyd clear the CR-Kais. I put everything together then cut the studs down with about 2-3 threads still showing and they clear fine.
Old 02-03-2011, 09:22 PM
  #1119
nf3d0149ab's Avatar
Sick pedals. Much better black.
Old 02-03-2011, 10:53 PM
  #1120
B A N N E D
friesm2000's Avatar
we do not need to hear about your gay sex life...
Quick Reply: My Build Thread - bordering on more BS! 56K Beware
