Idle relearn issues
Old Nov 11, 2022 | 10:19 PM
Braedin's Avatar
Question Idle relearn issues
It seems my 6 speed cl wont relearn the idle in anyway with a vacuum leak and i was wondering how to get around that since the bseries tb im using on the TL has a small vacuum leak and im thinking i wont be able to get the idle to relearn and it will just bounce the rpms endlessly and im not trying to buy a new throttle body anybody got some knowledge for me?
Old Nov 12, 2022 | 04:25 AM
To say the least, you are going to have to contend with the vacuum leak to find joy.
With that said, If you are using the p2r b series tb adapter you may need to modify the 'fittings' as discussed / depicted on the thread below?
Good Luck
J32A2 - low idle revs with B-series TB - AcuraZine - Acura Enthusiast Community
Old Nov 12, 2022 | 06:16 AM
619rcr's Avatar
Can you elaborate on what do you mean, by the throttle body has a small vacuum leak?
By design, throttle bodies in essence are a controlled vacuum leak. If you're getting surging (hunting and searching) idle, then you are getting too much air, which in turn the IAC is not going to be able to maintain control.
I probably should go back and update the thread that Zeta linked above with my fix.
Old Nov 12, 2022 | 07:26 PM
Braedin's Avatar
Yes sorry i mean i had my mechanic smoke test it when i put my bigger ported mani and the b series tb on my TL and said he got rid of all the leaks except one on the throttle body stem or shaft i forget exactly his wording but he said some leak from the factory or its's a spot you can see a leak start to happen with aftermarket tb's. So this leak isn't caused by my adapter i already dealt with that and p2rs iac being a little funky on my auto and having trouble with that tells me i might be set up for failure putting it on my 6 speed its a blocks billet 76mm b series tb btw
Old Nov 12, 2022 | 07:29 PM
Braedin's Avatar
This seems to be the issues im having with my acura TL thank you i will look into trying this.
Old Nov 13, 2022 | 08:27 AM
619rcr's Avatar
fwiw, I have the skunk2 74mm on a 6spd J35. I actually wanted the blox 76mm, but it was out of stock when I was looking. I am on 75A solid mounts, which eliminates some of the vacuum hose problem areas for these cars.
If anything, I would expect the manual to idle better, because the load from the torque converter would be removed. In any case good luck with finding a resolution to your idle problem.
Old Nov 13, 2022 | 09:30 AM
There is more discussion on the thread below if you have not already researched it.
Throttle Body - AcuraZine - Acura Enthusiast Community
Old Nov 13, 2022 | 04:22 PM
Braedin's Avatar
Yeah i got lucky finding it someone local on marketplace was selling it and thanks i think im going to try boring out p2rs iac vacuum line fittings on my auto and see if that helps before i get it on my 6 speed.
InspireJ32A
Nov 12, 2022 02:12 PM
guitarplayer16
Jun 10, 2015 10:39 PM
d4atls
Oct 17, 2014 05:23 PM
kkisgolfing
Jul 22, 2012 08:07 AM
zibadun
Jan 29, 2008 09:37 AM
