Why Soo Slow?????? My Gosh!
OK, i borrowed my friends 18" to put them on the CLP. Well it weight exact 51lbs each rim and tire combo. Well, when i drove around, the car seems lost all the punches, i sure felt its alot heavier the way the car drives, and also, i lost those "whenever i want" torque. Before, I can give gas at ANY rpm, and the car will just pull, i mean, you can feel it. But now, its sure feels like an Accord power. So are 18s SUPPOSE to slow you down alot? Cuz I heard even tho the wieght are the same, the gear ratio changed, so it will be way off..... Is this true? All the guys with 18s, what yall think????
BTW, anyone know how heavy are those CLP 16" rims and tires? Or Accord V6 rims and tires, cuz they are about the same weight! Thanks alot!
Powered By HONDA
i am not sure what is the weight of the clp rims or accords.but i am sure that your friend's 18" is kind of heavy.but what makes u slow maybe the width of the tire..but u do gain a lot of traction lol..what is the width of your friend's 18" tires.and what rim is that?
also when i was driving, i can kinda tell the gear ratio has been changed somehow, cuz the shift point are changed and stuff... hmm... i check on the status, each rim weight 22.9lbs. So it actually not that heavy! Since the stock rims are almost 21lbs anyway! hmm, so now i wonder where could be the problem coming from!
Powered By HONDA
do u also feel u need to press gas pedal harder in order to make car get moving?if so.that is only rims and tirs problems.do not worry about anything wrong with your car.
Re: Why Soo Slow?????? My Gosh!
Anyone else would like to add to this.
anybody?
anybody?
Here is the site's link -- it is not a calculator...
http://www.acura-cl.com/forums/showt...threadid=50659
There is a link -- I got the pictures and formulas from "Fizzics Fizzle": http://library.thinkquest.org/16600/...linertia.shtml
