Who's got nitrous?
Old Mar 23, 2006 | 12:47 PM
mrsteve's Avatar
Who's got nitrous?
Any 6-speed guys? Pretty much everyone using the ZEX kit?
Old Mar 23, 2006 | 01:09 PM
mattg's Avatar
repost
mrsteve's Avatar
Old Mar 23, 2006 | 01:10 PM
mrsteve's Avatar
I think I'm gonna do it.
Old Mar 23, 2006 | 01:12 PM
brianlin87's Avatar
ASM I.S. Design FTW.
I thought you were gonna sell your car?
mattg's Avatar
13.25 @ 105.7
beat it, nga.
Old Mar 23, 2006 | 01:14 PM
mrsteve's Avatar
Nobody will buy it for what I'm asking so screw it... I'll slap a bottle on it.
Old Mar 23, 2006 | 01:15 PM
brianlin87's Avatar
Old Mar 23, 2006 | 01:21 PM
mrsteve's Avatar
Matt... I need the ZEX dry kit, bottle warmer, purge kit, and blow down tube. Anything else? Window switch maybe so I don't spray beyond the rev limiter?
Old Mar 23, 2006 | 01:34 PM
mattg's Avatar
yeah, I wouldn't recommend spraying past 7100 rpms.
Old Mar 23, 2006 | 01:43 PM
mrsteve's Avatar
~$8-900??
Old Mar 23, 2006 | 01:47 PM
mattg's Avatar
http://cgi.ebay.com/ebaymotors/ZEX-D...48697224QQrdZ1
Old Mar 23, 2006 | 02:02 PM
brianlin87's Avatar
why dry kit instead of a wet kit?
Old Mar 23, 2006 | 02:04 PM
mrsteve's Avatar
Easier to install.
Old Mar 24, 2006 | 03:01 PM
SanJoseRoller's Avatar
I SMELL NAWZ
if your car wasnt a 6 speed and it was a auto you wouldnt need to the window switch right?
im assumeing the tranny shifts it for you no human error?
Old Mar 24, 2006 | 07:12 PM
mrsteve's Avatar
You don't want to hit the rev limiter while you are spraying.
Old Mar 24, 2006 | 08:24 PM
rtatsutani's Avatar
Never had a clean run
Zex's control module should handle that type of problem and cut the nitrous.
Old Mar 24, 2006 | 09:46 PM
hoss's Avatar
hoss
So what about the longevity of nitrous. How does this affect the engine with continual use. By this I do not mean using it everyday and using an unsafe amount. I mean if you used it moderatly and used say a 65 or 75 shot. Does anyone know how this would where on your engine or would it be just like using a forced induction kit.
Old Mar 24, 2006 | 11:30 PM
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
What's up Steve. I believe Mitch(acuracls6spd) has nitrous on his Cl 6 speed. I can't remember which setup he runs but I believe he ran some low 13s with his setup. He's the one with the red car with the carbon fiber trunk.
By the way, when I was running nitrous. I got my tank filled up at Speed unlimited but don't who else sells it.
Old Mar 25, 2006 | 01:12 AM
rtatsutani's Avatar
The main issue with nitrous is the sudden burst of energy. yeah FI can normally give you around 40-60+HP, but smoothly delivered. Nitrous is a one time deal, once you press that button, you get 75HP instantly! That causes wear to your entire drivetrain as well as your engine components. If you moderately use it (a handful of times at the track a few times a month) it should not cause you any engine issues other than constant plug checks/changes. If you overuse it or over jet it, well, the sky is the limit with the amount of things that can break. I speak from experience :ROFL:
Old Apr 29, 2006 | 02:40 AM
All Mine's Avatar
I'm a Vagiterian.
Old Apr 29, 2006 | 02:41 AM
All Mine's Avatar
I'm a Vagiterian.
Sorry for the resurection.
Me, nukka.
Old Apr 29, 2006 | 07:59 AM
6peedSleepR's Avatar
I Heart 6 Gears.
Originally Posted by mattg
13.25 @ 105.7
beat it, nga.
I hate you! sik time..
Old Apr 29, 2006 | 10:07 AM
CLsuperhero's Avatar
you had to have an almost perfect reaction time.
Old Apr 29, 2006 | 10:49 AM
mclarenf3387's Avatar
Unless you run heads up, most strips will only start timing when you start going.
Old Apr 29, 2006 | 01:23 PM
mrsteve's Avatar
Reaction time has nothing to do with E.T.
Old Apr 29, 2006 | 01:50 PM
jeffyncs's Avatar
comptech
how much are you asking for your car?
Old Apr 29, 2006 | 01:59 PM
mrsteve's Avatar
$18,500. It has 56k miles now.
Old Apr 29, 2006 | 03:38 PM
mattg's Avatar
if you meant 60', it was a 2.0, on 18" street tires.
Old Apr 29, 2006 | 07:00 PM
shineynitelite's Avatar
NAWWWWSSSSSS
2.0 is a sweet 60 foot time.
so did you ever strap the bottle
Old Apr 29, 2006 | 07:43 PM
All Mine's Avatar
I'm a Vagiterian.
Picking mine up tomorrow morning. Yeah baby! Zex 75 shot.
Old Apr 29, 2006 | 07:58 PM
NAWWWWSSSSSS
remember, nitrous is a drug.. use it wisely and with respect.
other than that hold on tight, 75 shot should feel great....... i hope you have some sticky tires
Old Apr 29, 2006 | 08:30 PM
All Mine's Avatar
I'm a Vagiterian.
I won't be spraying off the line, and I have an automagic. Sooo.... I gotta be carefuler (shut up, i know it's not a word)
Old Apr 30, 2006 | 09:50 AM
NAWWWWSSSSSS
you probably wont be spraying in first at all
Old Apr 30, 2006 | 11:46 AM
mattg's Avatar
strap the bottle?
I sprayed in first as soon as I got traction. Spaying from 2nd only netted mid 13's if I remember correctly.
there's a thread in here somewhere that documents all of my nitrous runs.
Old Apr 30, 2006 | 12:13 PM
All Mine's Avatar
I'm a Vagiterian.
strap the bottle?
Did you have a button, or the brain that did it all for you? I'm skurrr'd that since it's most likely a full-throttle switch, it may spray while the tranny is in neutral shifting gears and do all sorts of bad things.
Old Apr 30, 2006 | 01:08 PM
johntypes's Avatar
14.10 @100.07 mph 241.1 hp 199.9 totque 13.51 @ 106.66 mph 75 Shot 291.1 hp 275.6torque
Old Apr 30, 2006 | 02:45 PM
NAWWWWSSSSSS
strap the bottle?
not you, strap the bottle aka hook it up in the car
Old Apr 30, 2006 | 02:46 PM
NAWWWWSSSSSS
if you have any doubts just get a button, or if you have the money get a window switch
Old Apr 30, 2006 | 03:11 PM
All Mine's Avatar
I'm a Vagiterian.
What's that for?
