What N/A mods are left?
Old May 14, 2007 | 02:27 PM
CL-Future's Avatar
Lives in Boost
I've got XS headers jet hot coated, spacers, Mugen mods, Icebox, UR pulley and NRG dampener. What else is there that will give me noticeable performance gains? I don't have any suspension mods yet, but I do have cross drilled and slotted rotors all the way around. I could stand to replace the clutch since I'm still on the original after 95k miles.
I went to the track Saturday and only ran 4 times with a best of a 14.4 @ 96. I've been to the track before to spectate but this was my first time actually running. I didn't red light once and kind of powerfully eased out of 1st on take off to avoid wheel hop and wheel spin. I'd like to get to lower 14's or high 13's if possible.
Any input would be appreciated...
Old May 14, 2007 | 03:11 PM
SuperTrooper169's Avatar
In the Mid-South meow
I did the throttle body coolant bypass recently and it feels like it gave me a little more HP, but it could all be psychological. Other than that there's not much left that I can think of besides boring out the TB or a port and polish.
Old May 14, 2007 | 03:12 PM
fuzzy02CLS's Avatar
You can loose weight by getting light rims. Also once you get some suspension mods you'll be able to transfer the power to the ground better & lower your times.
Old May 14, 2007 | 03:27 PM
CL-Future's Avatar
Lives in Boost
Thanks guys. I'll probably do suspension (springs/shocks) and see how that helps...
Old May 14, 2007 | 03:31 PM
3.2quadCLS's Avatar
get the Apexi VAFC. It will compliment all those mods perfectly. You should see some nice gains with those already existing mods.
Old May 14, 2007 | 04:01 PM
2CLean's Avatar
Well...it's kinda fast...
I was going to say that. Upgrade the ECU and a nice tune, you'll see/feel a nice bump in HP. As far as bolt ons, a free flowing cat or straight pipe (if you're not interested in passing emissions) should net you a few extra ponies.
Other than that, weight reduction is your best bet. If you're really serious about all motor power, look into some custom cams with a more aggressive profile
Old May 14, 2007 | 04:16 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
3.5L conversion!
Old May 14, 2007 | 04:27 PM
LIPPSTUH's Avatar
Unregistered user
cooling mods...
Old May 14, 2007 | 04:35 PM
weaselbob74's Avatar
07 ASM TL
Cams
Old May 14, 2007 | 04:36 PM
07 ASM TL
V-10 Crate Engine
Old May 14, 2007 | 05:12 PM
CL-Future's Avatar
Lives in Boost
Originally Posted by weaselbob74
V-10 Crate Engine
LOL^^^ I'd like to keep the Acura heritage.
I was thinking about the 3.5L conversion but I don't have the time and know how for that.
I was following the cams that are supposed to be developed possibly so we'll see how that goes.
Where would I get the VAFC from? What kind of things could I adjust w/ that?
Old May 14, 2007 | 05:35 PM
hemhaw's Avatar
Drinking Beer In
You've exceeded 90% of the NA HP gains that you are likely to get. VAFC gains will be minimal, as will any exhaust mods (beyond headers).
Go for an engine torque damper to help your hookup, and lighter wheels.
Old May 14, 2007 | 05:36 PM
BigLizard's Avatar
Moderator Alumnus
Big bore throttle body, boring out/honing out the entire intake manifold, full custom exhaust...(RT high flow cat, custom resonator, mufflers, and piping), larger FPR, larger fuel pump, larger fuel injectors, UniChip or VAFC...the list goes on...
Obviously suspension...sways, upper strut bar, LSB, springs, dampers, or coilovers, camber kit is in order...
Old May 14, 2007 | 05:56 PM
CL-Future's Avatar
Lives in Boost
I've got the front NRG damper on. I haven't put the other one on the rear yet but will in the future.
I'll probably work on suspension for now since I haven't explored that world yet and get that as tight as possible. Thanks for the ideas...
Old May 14, 2007 | 07:35 PM
CL-Future's Avatar
Lives in Boost
Here's one of the races. I was going against my cousin in the Eclipse. He's got a new clutch, 16G turbo and exhaust cutout and didn't really tune anything yet, otherwise he'd be in the 13's. I lost two of them by hundreths of a second. This one by .02 and the other by .08. I was pissed but we'll go again soon and I'll have a new clutch by then and hopefully some suspension mods.
Race #3
Old May 14, 2007 | 07:46 PM
mrsteve's Avatar
no.... no.... and no
There's absolutely not need to upgrade the fuel system on a NA car.
A "larger" FPR won't do a thing because he'll never exceed vacuum and thanks to OBDII any increase in static pressure will be corrected by short term and long term fuel trim to bring the mixture back to a stoichiometric ratio. An increase or decrease in static fuel pressure will be instantly detected by the ECU as a rich or lean condition and adjust the fuel trim values accordingly so that the amount of fuel flowing through the injectors is the same at 60psi of static pressure or 45psi of static pressure, or whatever other pressure you try to increase to.
A "larger" fuel pump won't do a thing because he'll never require more fuel than what the stock pump provides and a "larger" fuel pump (should say higher flow capacity fuel pump) will only send as much fuel as the FPR senses is required.
Larger injectors won't be of any use because he doesn't have the airflow (and can't achieve it without boost or nitrous) to warrant an increase in flow. Not to mention with the suggested UniChip or VAFC they'll be useless because neither of those two tools have any control over the injectors.
Old May 14, 2007 | 07:48 PM
mrsteve's Avatar
Race #3
What are your 60' times? What tires are you running?
I would skip the expense of opening up the intake manifold.
I'd start with suspension. Parts really aren't that expensive. I'd recommend the H&R Sport springs and Tokico HP blues. That set up should run you around $450 and plant the car nicely. Sways are nice but they won't help you leave the line any quicker. Also, pick up a Neuspeed short shifter.
Old May 14, 2007 | 07:59 PM
CL-Future's Avatar
Lives in Boost
60' times were 2.339 (14.57 @ 94.01), 2.309 (14.488 @ 95.87) and 2.341 (14.461 @ 96.59)
I got better after every race. I'm running Yoko EVS 100's with regular tire pressure.
I was going to get the H&R Sports w/ Bilstein shocks. Are those about the same as Tokico's or worse? I'd like it stiff but not too harsh of a ride.
Old May 14, 2007 | 08:03 PM
mrsteve's Avatar
No experience with them but I don't see how you could go wrong.
Oh and you need to cut down on those 60' times!!! You should be consistently in the 2.1s. That right there will drop you 0.4 off your ET
Old May 14, 2007 | 08:23 PM
CL-Future's Avatar
Lives in Boost
lol, I'll see what I can do. I'm sure the more I go the better I'll get. What do sways do, tighten up the rear end?
Thanks for your input/help.
Old May 14, 2007 | 09:35 PM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Any experience with the Neuspeed short shifter? Is it worth it? Also, if you lets say busted a shifter cable whats the best place to get only one or repair the existing cable sleeve on the 1/3/5 shifter cable?
Old May 14, 2007 | 09:39 PM
mrsteve's Avatar
I have the Neuspeed shifter and I like it. Shortens the up and down throw.
Try oemacuraparts.com for the shift cable
Old May 14, 2007 | 10:00 PM
Thanks for the input, still cant find the item I want especially on oemacuraparts.com there menus are far more confusing, while on acuraoemparts.com their drop down menu was just incorrect for that car.
Looking for item number 8 just for the CL-S 6spd or a way to repair the black sleeve that prevents the cable from kinking outwards and giving you that very sloppy feeling.
Old May 14, 2007 | 10:25 PM
BigLizard's Avatar
Moderator Alumnus
I was thinking he'd might go boosted one day besides just wanting to stay NA......
I did read CleanCLs thread after I posted
Old May 14, 2007 | 10:39 PM
m733l's Avatar
rt hi flow cat.
Old May 14, 2007 | 11:24 PM
tnobori1's Avatar
Missing my
Nothing like getting opinions backed with facts! Nice post!
Old May 16, 2007 | 05:19 PM
CLsuperhero's Avatar
NOS is a good choice if you just want to have that temporary burst of power at the track.
Old May 16, 2007 | 05:32 PM
tommyguy2's Avatar
whats the stock vtec engagement point? I wonder if the vtec controller would be of any use?
Old May 16, 2007 | 05:45 PM
BigLizard's Avatar
Moderator Alumnus
Chod teh Wackos page = very useful
(in my sig)
What RPM does VTEC engage?
Type S: 4800 RPM
Type P: 5500 RPM
Return to Contents
Keep in mind those VTEC engagements are for automatics...
Old May 16, 2007 | 10:08 PM
hemhaw's Avatar
Drinking Beer In
Understatement of the year. I still refer to it often
Old May 16, 2007 | 10:43 PM
LIPPSTUH's Avatar
Unregistered user
wouldn't cooling mods be a consideration. NO power gains.. but it would be better for ur car since u have so many power mods...
i'm not to familiar with the topic, i've read cleancl's thread about it though.
Old May 16, 2007 | 10:46 PM
CL-Future's Avatar
Lives in Boost
Yeah I've got the Mugen mods and Thermoblock spacers already as well as Jet Hot headers...
Old May 17, 2007 | 09:20 AM
07 ASM TL
(in my sig)
Type S: 4800 RPM
Type P: 5500 RPM
Return to Contents
Isn't it 4800 for the 6-sp too?
Old May 17, 2007 | 09:41 AM
LIPPSTUH's Avatar
Unregistered user
yup 6-speed is only type-s (not anything else) so it's the same thing.
Old May 17, 2007 | 09:52 AM
07 ASM TL
I just wasn't sure if it was at the same RPM
Old May 17, 2007 | 10:33 AM
mrsteve's Avatar
It is. Not sure why GreenMachine added that last statement. Same motor in the automatic and 6-speed. 4800 rpm engages VTEC.
Old May 17, 2007 | 06:11 PM
BigLizard's Avatar
Moderator Alumnus
Cuz the page is old...that's what I went off of...
i was too lazy to
Old May 19, 2007 | 09:57 PM
Louie11's Avatar
Looks like you went to Byron. that's one hell of a ride to get there.
Old May 19, 2007 | 10:09 PM
CL-Future's Avatar
Lives in Boost
it was. It was my first time there too, didn't know it was so long of a ride. But it was fun. There was a new 2007 Porsche Turbo running 12's all day. The last run I saw him run was a 12 flat. There were no Acuras there though
I just need to get some more runs in, a new clutch and some stiffer suspension and I'll be able to get low 14's or a 13.9.
Old May 20, 2007 | 10:10 AM
Louie11's Avatar
I have been there twice. I usually go to union grove instead, I've been there about eight times.
chasingthecool
Mar 9, 2017 05:16 PM
LoneRonin
Jan 4, 2016 01:03 AM
rhdune16
Sep 28, 2015 11:31 AM
jmaxima03
Sep 27, 2015 10:22 AM
ripit
Sep 26, 2015 06:19 PM
