Weak Starter?
Old Apr 6, 2009 | 08:17 AM
CRXZC's Avatar
Weak Starter?
Anybody else's starter sound like a dead cat?
Mine turns over quite slowly, has a bit of a whine, I'm not sure if this is normal. I drove a friend's Odyssey with the 3.5L V6 and it definitely turned over ALOT faster, with no whine.
I have a feeling my starter's on it's way out. I've already changed the battery recently. Has anybody replaced their starter? Do you need to remove the axle to get it out (like the older 3.2TLs)?
Or do these cars normally turn over quite slowly on starting. I don't have anything to compare mine to.
Thanks!
-Mark
Old Apr 6, 2009 | 08:50 AM
civicdrivr's Avatar
Mine is slow to start. I want to do the "Big 3" upgrade.
On a side note, what year is your CRX?
Old Apr 6, 2009 | 01:34 PM
aznboi2424's Avatar
check your battery. maybe its low on CCAs. Mine has been starting slower recently.
Old Apr 6, 2009 | 02:00 PM
CRXZC's Avatar
Battery is Brand New (like a month or so) from Acura, and is a lot more CCA's then the factory one. I don't think it's the battery.
I notice sometimes after driving, and parking for a few minutes, it's even slower to turn over.
It's obviously starting fine, just worries me that one day it's just not going to start. But if it's just the way it is, then I suppose I have nothing to worry about. Colder temperatures don't seem to have any bearing - starts the same.
I was thinking maybe bad grounds etc., but if everybody's in the same boat it's probably just the design.
My dad's BMW Z4 sounds almost the same on startup.
Old Apr 6, 2009 | 02:01 PM
CRXZC's Avatar
It WAS a 91' Si-SE with a B16 and some SiR goodies... but a few Canadian Winters took their tole... so I parted it out.
Just haven't changed my online nick.
Old Apr 6, 2009 | 02:23 PM
CRXZC's Avatar
By the "Big 3" upgrade, are you talking upgrading to the Big 3 Engine, or retrofitting a 3.5L starter on the 3.2? Is this common knowledge or something?
Old Apr 7, 2009 | 07:15 PM
civicdrivr's Avatar
Search for Big 3. You swap out power/ground cables and it supposedly helps out.
My CL is difficult to start shortly after I run it. Don't know why, but it pisses me off.
I have noticed that since I installed the underdrive pulley it starts alittle bit easier. Not much, but it's noticable.
Old Apr 7, 2009 | 09:04 PM
fuzzy02CLS's Avatar
The fuel pump takes a sec to prime. Try turning it to run for a sec then start it.
Old Apr 7, 2009 | 09:39 PM
CRXZC's Avatar
I'm assuming you're responding to the user above.
Mine has no issues starting, just turns over reallly slow.
I'll check into this "Big 3" upgrade...thanks!
Old Apr 7, 2009 | 09:43 PM
CRXZC's Avatar
Clearly I'm handicapped, I can't seem to find any info on this.
Could you help?
Thanks!
Old Apr 7, 2009 | 10:14 PM
fuzzy02CLS's Avatar
I'm talking to everyone. The car starts hard cause the fuel pump is priming.
It could be the starter as well.
All 3 of my CL's cranked a bit slow compared to other cars.
Old Apr 8, 2009 | 09:52 AM
civicdrivr's Avatar
Yea, I meant that mine cranks slowly after it sits for a short period of time, not difficult to start like it won't turn over or anything.
A quick google search for Big 3 Upgrade got me this:
http://forum.sounddomain.com/ubbthre.../312025/page/1
Old Apr 8, 2009 | 12:10 PM
CRXZC's Avatar
Thanks... yeah I found this last night.
I wonder if it would actually make a difference... hmm
Old Apr 8, 2009 | 01:14 PM
civicdrivr's Avatar
I remember seeing a member here starting a thread about. They said it made a difference. Im willing to try it.
Old Apr 10, 2009 | 06:26 PM
Billy Sacco's Avatar
Kilos of yayo in
It made a difference in my car. After removing it mine starts noticeably slower so I am putting it back in for sure.
Old Apr 10, 2009 | 07:50 PM
ThinJim's Avatar
If you need a starter, I have a very good used one that I took off a car I stripped down. people can vouch for me, 55.00 shipped if you want it.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
lovic87
Sep 15, 2015 06:07 PM
