Water injection?
Old Jan 20, 2005 | 08:13 AM
Chemmech's Avatar
Water injection?
Anyone know about the Jackson water injection system? I heard that they are really good at putting off detonation, pinging, at high RPM. I'm having a problem with missfiring at high RPM and wondering if this might help out?
Old Jan 20, 2005 | 09:05 AM
SiGGy's Avatar
Moderator Alumnus
Unless you running some sorta forced induction system you do not need a water injection or propane injection system.
NM.
I see you have a 9 PSI S/C in your sig.
What do the F/A graphs on your dyno show?
Old Jan 20, 2005 | 09:38 AM
BoostedM3's Avatar
Bagged hybrid
Have you measured your IAT at full boost?
I would recommend any of these
http://www.aquamist.co.uk/cp/cp.html
Old Jan 20, 2005 | 10:51 AM
Chemmech's Avatar
Which system did you end up getting Ronnie?
Old Jan 20, 2005 | 01:54 PM
scalbert's Avatar
You really need to check the A/F numbers, we need to see where that is at before resorting to H2O injection.
Old Jan 20, 2005 | 03:30 PM
av6ent's Avatar
Yeah, try to use wideband AFR monitor like ZT-2 by Zeitronix and see where you at especially up top. That way you can see your AFR/BOOST/EGT values while your driving and analyze later through data logger. Or put it on the dyno (Dynojet 248c) and post the AFR.
Old Jan 20, 2005 | 05:24 PM
Chemmech's Avatar
I guess I can't procrastinate on my dyno run much longer.
Old Jan 20, 2005 | 05:51 PM
BoostedM3's Avatar
Bagged hybrid
I got the aquamist 1S system w/ pre-charged accumulation tank. My car tends to run rich as I can smell the uncombusted gasoline when I removed the intake manifold. My AFR is around 12.5-13 with injection.
Old Jan 26, 2005 | 12:04 PM
Chemmech's Avatar
ok, i hooked my obd2 scan tool up to my car. i was seeing temps from 90 to 160, 60 degrees f ambient, at full throttle; however, my water pump has been making strange noises (squeeling like pig), and i had a hose that was slightly restricted. i ordered more fittings and a new pump from jegs to fix that problem, expensive as shit!
anyway, scalbert, what types of temps were you seeing at wot?
Old Jan 26, 2005 | 12:16 PM
scalbert's Avatar
With 70 ambient, I would see 90 - 100 F post IC.
I'm curious about the IAT readings though. The IAT is very slow to respond and I never registered that high. My readins were taken with thermocouples.
Old Jan 26, 2005 | 12:18 PM
Chemmech's Avatar
Wow! I'm runnin hot! oh well, i'll check it out again after i get my stuff installed. is 20gpm a good enough flow?
Old Jan 26, 2005 | 12:26 PM
BoostedM3's Avatar
Bagged hybrid
Man, I wish I was running those IAT temps. W/o water injection, I was running 160ish WOT at 70 ambient.
Old Jan 26, 2005 | 02:04 PM
scalbert's Avatar
Way more than enough. That should be some great flow!!
Old Jan 26, 2005 | 04:09 PM
Chemmech's Avatar
sucker cost $175 :ouchdammit: oh well
Old Jan 26, 2005 | 06:50 PM
Smitty's Avatar
pssst, Steve i need that part you are suppose to ship me by mid Febuary...
, good thinking Chemmech, but like you said.. kinda expensive.
Old Jan 26, 2005 | 07:08 PM
scalbert's Avatar
Thanks for the reminder, I did forget.
Timmy18
Oct 17, 2015 03:58 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
hrothgar02
Sep 28, 2015 11:08 AM
STL TL-S
Sep 23, 2015 08:52 PM
