Trunk lid bars
Old Feb 27, 2008 | 01:09 PM
loweredCL's Avatar
Trunk lid bars
Hello all,
On my 2003 CL, I took out the stock (weak) Bose speakers and installed a good set of 6x9 on the back deck. The problem I have is that they speakers have a bigger magnet and the two bars ( I'm guessing tension bars) that help keep the trunk lid up hit and rub on my speakers!! They also make noise anytime I hit a bump. Also, since I added my spoiler, the trunk lid at times won't stay open, and other times it barely does. Does anyone know how to remove those bars?? To the people that have spoilers on their car, do you have a problem with the trunk lid not staying open, and how did you fix that problem? Lastly, I'm thinking of putting a strut to hold open the trunk lid. Has anyone tried that before? Did it work?? thanks
Old Mar 2, 2008 | 09:16 PM
GreenMonster's Avatar
If I recall correctly, there's a stronger spring (tension bars) that's needed when the rear spoiler is added. I had my spoiler installed by the dealer, so I'm exactly sure.
There's some talk about the springs here (see post 18-20 or so):
https://acurazine.com/forums/showthread.php?t=85009
Old Mar 2, 2008 | 09:19 PM
For the speaker stuff, you might to check out the audio forum here:
https://acurazine.com/forums/audio-video-electronics-navigation-22/
to see if anyone has run into the same issue...
Old Mar 2, 2008 | 09:23 PM
Never Summer's Avatar
There are stronger springs for a trunk with a spoiler. I have the bigger ones I need to put in my TL, but I've heard it's really dangerous to mess with the torsion bars.
Old Mar 2, 2008 | 09:30 PM
Andy2.3's Avatar
Azine's only Punk PFC
How so?
Old Mar 2, 2008 | 10:15 PM
fuzzy02CLS's Avatar
There's a tool you can buy. I ordered 1 myself. I should have it next week sometime.
http://www.bernardiparts.com/Product...=07AAF-SNAA100
Does anyone actually have a part # for the HD trunk springs? They were not listed in the parts computers of 2 dealers by me, & I don't see them online.(just the regular ones) I have a feeling they only came with the spoiler kit.
Old Mar 2, 2008 | 10:28 PM
NSXNEXT's Avatar
Yeah but the stiffer torsion springs will still have clearance problems with your speakers. Your best bet is to install a set of hydraulics to hold the trunk lid up.
Old Mar 2, 2008 | 11:23 PM
Originally Posted by Andy2.3
How so?
They are in there with some pretty high tension, I've heard if you try and pull them out without the tool fuzzy is talking about you can put an eye out.
Fuzzy, to answer your question, this is the part number for the TL torsion bars:
Originally Posted by brandonnguyen
That part number that i have on the box is: 08F13-S0K-201R2
Old Mar 3, 2008 | 08:25 AM
There's a different part number listed in the spoiler thread I linked above:
08f13-s3m-200r1
I'm not sure if they are the stiffer ones or not
Old Mar 3, 2008 | 12:30 PM
Zippee's Avatar
The special tool might be a little easier and might be worth it if you did a lot of them like at a dealer.
It's not particularly dangerous, I've changed them out without the special tool, just improvised with the handle of a crescent wrench. Worked fine.
Old Mar 3, 2008 | 02:57 PM
fuzzy02CLS's Avatar
I tried that way. I'm not messing with that it slipped once & flew out of my hand up at me. I'd rather spend the $ on a tool.
Old Mar 3, 2008 | 03:19 PM
DLntheCL's Avatar
when you hit the truck release button, is your trunk lid supposed to fully open? when i got my CL the little square shaped metal bracket that held the bars in place, welded to the upper trunk, was barely holding on so i broke it off, simply by pulling it off. car does have a spoiler but it wasnt original so maybe i need new torsion bars and that bracket back on.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hashbrown
Sep 29, 2015 12:13 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
