Throttle Cable Ripped while on the freeway.
Si Vis Pacem, Para Bellum
Just as the title states that what happened. Luckily i was still going fast enough to use cruise control to control the throttle (the pedal was dead) till i got off on my exit. then i improvised and got it to my best friends shop. crazy experience. ever happen to any of you guys? common problem? probable cause?
Socal
1 Post
smart thinkin on that cruise control.... wat did u do on the street?
o seen u were in pasadena.... check it son just in case u dont visit the meet forum often
https://acurazine.com/forums/acurazine-clubs-meets-15/so-cal-surf-cruise-%7Eapril-18-2009%7E-711767/
I shave my change purse
Happened to me when I had my 96 Altima, only worse. My cable was frayed and got caught in a WOT position, I attempted to use the brakes but they were of no use. So I quickly threw the gear to neutral and pulled over to the shoulder and immediately killed the ignition. Scary
Blown is Best
I haven't heard of this happening but I can definitely see how it could. Repositioning the throttle body on an SC moves the cables in a way that they can kink. I've seen mine settle into a position that isn't straight.
Blown is Best
My brother had a Chevelle with a pretty hot motor and the throttle was pinned wide open once on me when the motor mount broke. That was definitely an "OH SHIT" moment.
xsilverhawkx
09-28-2015 06:51 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
