Thermoblock Spacers
Old Jul 31, 2007 | 06:56 PM
Nov!ce's Avatar
White Type-S
Cool Thermoblock Spacers
Where is the best/least expensive place to purchase this part? Thanks in advance.
Old Jul 31, 2007 | 07:08 PM
Nov!ce's Avatar
White Type-S
Uh, never mind. I searched a lil' more and found the link to outlaw engineering. One question though: Is it a straight bolt-on piece or do I have to modify my hood for it to fit? I have a '01 CL-S? I need to know, 'cause I'm ready to order one now.
Old Jul 31, 2007 | 07:35 PM
fsttyms1's Avatar
straight bolt on
Old Jul 31, 2007 | 07:38 PM
CLsuperhero's Avatar
straight bolt on. it goes on the throttle body and the other goes on the intake manifold. you can modify your hood if it floats your boat but it would ridiculous and unnecessary in this case.
Old Jul 31, 2007 | 07:43 PM
Nov!ce's Avatar
White Type-S
Thank you. Ordering now.
Old Jul 31, 2007 | 08:39 PM
fuzzy02CLS's Avatar
It's not a total bolt on........
You will have to unscrew your stock studs on the intake & TB & install the new longer ones. So make sure you don't break or damage these if you ever want to put them back on.
Old Jul 31, 2007 | 11:38 PM
m733l's Avatar
i had to cut the engine cover a little so that it would fit the new placement of the plug that stick out above the cover. i guess if you don't want the cover back on then it doesn't matter.
Old Aug 7, 2007 | 01:45 AM
LIPPSTUH's Avatar
Unregistered user
there isn't different fitments for stick and auto right?
Old Aug 7, 2007 | 02:12 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Same motor right?
Old Aug 7, 2007 | 02:46 AM
LIPPSTUH's Avatar
Unregistered user
lol right, just making sure. i believe there is a small different from cl and cl-s
Old Aug 7, 2007 | 02:49 AM
There sure is but I was refering to the motor differences of the CLS AT/MT
Old Aug 7, 2007 | 02:53 AM
LIPPSTUH's Avatar
Unregistered user
yeah thanks for the quick responses =]
Old Aug 7, 2007 | 02:55 AM
No problemo
Old Aug 7, 2007 | 09:37 AM
poisx7's Avatar
DId u install urself ??, how easy is this to install i am not to mechanically inclinded. Can u rate pls.
i might consider it.
Do u have any pics of how bad a cut u had to make on the engine cover b4 the things cud fit
I thought there was a DIY on that but i never found it.
Old Aug 15, 2007 | 12:08 PM
Nov!ce's Avatar
White Type-S
I received 'em in the mail last week.
Old Aug 15, 2007 | 12:48 PM
CL-Future's Avatar
Lives in Boost
There's instructions that come with the kit when you order it from Outlaw Engineering. It's pretty straigh forward. Just make sure you don't strip/break any of the bolts when taking the intake manifold/plenum off. It's really simple. Just unbolt everything, place the spacer on the block and bolt everything back up. Don't forget to reattach any wires you had to unclip as well. Should only take like 20 minutes. Also, remember to place a clean cloth or towel in the intake when placing the spacer on the throttle body.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
rockvilleTL
Sep 19, 2015 04:44 PM
yvr_tsx
Sep 15, 2015 01:14 PM
