TCS and Check engine light again... =(
Old Jun 9, 2007 | 06:16 AM
BigLizard's Avatar
Moderator Alumnus
Unhappy TCS and Check engine light again... =(
On my way home from work tonight I felt the gears slipping from 2nd to 3rd, and 3rd to 4th. Then when I'm not even 2 minutes away from home the TCS and engine light pop on. I'm pissed because my car was bandaided with the stupid jet cooler at 80,xxx miles and I'm sure the tranny is passing away at over 124,xxx miles so Acura wouldn't have to pay to have a new tranny replaced.
Just my dumb luck before I go to Japan for two weeks.
Old Jun 9, 2007 | 06:22 AM
iisylentii's Avatar
ALL SHOW AND NO GO
Sounds like the 6 speed swaps coming a little sooner then we thought
Old Jun 9, 2007 | 10:59 AM
All Mine's Avatar
I'm a Vagiterian.
Or a tree falling in it, miraculously..
Old Jun 9, 2007 | 07:57 PM
jproy's Avatar
MP90 uninstalled
Trees do just fall over some times.
Old Jun 10, 2007 | 12:04 AM
nbennettksu's Avatar
i heart latin chicks
hey man those lights came on my car; also thought that I felt the tranny slipping. hooked it up to an obdII scanner and it was just random misfires, witch can also make it feel like its slipping or sputtering...
Old Jun 10, 2007 | 01:20 AM
BigLizard's Avatar
Moderator Alumnus
I pulled the code from my actron reader and it was....P0740!
TCC Circuit Malfunction...Torque convertor is gone, i tried the TC test and failed.
Other information that popped up was
Throttle Position: 23.9%
Engine RPM: 2092
Load Value: 70.9%
MAP Sensor: 72 KPA
Coolant Temp: 163 degrees F
Intake air temp: 82 degrees F
Short term fuel Trim 1: 0.0%
Long term fuel Trim 1: 3.1%
Short term fuel Trim 3: Negative -100.6%
Long term fuel Trim 3: Same as above
Vehicle speed: 66 MPH
Fuel System 1: Closed
Old Jun 10, 2007 | 07:24 PM
nice, my SRS light just came on....
Old Jun 12, 2007 | 11:53 AM
spiderman3098's Avatar
i have a question for u guys i know its not legal, but what if u just replace your tachometers with say something that say like 99,000 miles. would the dealership know that it has been changed out like or do they run your vin number agaisnt dmv records?
Old Jun 12, 2007 | 12:39 PM
CL-S_undance Gold's Avatar
QUOTE=spiderman3098]i have a question for u guys i know its not legal, but what if u just replace your tachometers with say something that say like 99,000 miles. would the dealership know that it has been changed out like or do they run your vin number agaisnt dmv records?[/QUOTE]
nah just draw over it with a sharpie, theyll never know......[
Old Jun 12, 2007 | 12:56 PM
OrngeAc3.2's Avatar
nah just draw over it with a sharpie, theyll never know......[[/QUOTE]
Old Jun 13, 2007 | 12:40 AM
ill take that as a yes then, i guess, but my mechanic was telling me to do that if your tranny ever went out he said the dealers around my area are hella dumb and never check that. he said hes done it to like 4-5 accords and a couple rsxes and never had a problem with them saying your mileage doesn't check out. idk but it could be worth a try 200 bux for a used tach at the junkyard compared to 3000 for a tranny rebuild.
Old Jun 15, 2007 | 04:22 PM
o1s's Avatar
o1s
ever been to prison?
Old Jun 15, 2007 | 05:00 PM
JadeFox's Avatar
yay! for SRS xtension
this would fall into the "I'm gonna drain my tranny fluid and go driving" catagory
Old Jun 15, 2007 | 05:02 PM
BigLizard's Avatar
Moderator Alumnus
^wtf are you refering to and what are you talking about?
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
