Started on some in home porting
Old 02-10-2013, 08:43 PM
  #1201
3.5 psi
gnuts's Avatar
Impressive! Nice 60 foot. I Need To Learn How To Launch
richardparker (02-11-2013)
Old 02-10-2013, 09:18 PM
  #1202
03 CLS-6
1foxbody's Avatar
Congrats on the new times! Just for reference when I ran the 12.5@112 my 1/8 mile times was 8.1@90 with a 1.8 60ft. I was still on the oem clutch setup and had some slippage problems but it still ran decent when it did grab. I'm curious what your 1/4 mile et and trap would be?!?! I bet it's most likely in the high 12's! Congrats again keep up the good work!
Old 02-11-2013, 06:37 AM
  #1203
3.7L Nitrous Breathing CL
richardparker's Avatar
Wasn't that with +200 shot and slicks ?
For those who don't drag and want a idea how fast the car is.
I think fox was running the same 1/8 times as me with 145 shot,custom headers, fully bolted and slicks.
Atleast thats what I seen on drag times.
I got work to do to get 8.1's N/A but,8.2's are next for sure with the sunroof shut and a light weight lithium battery
1foxbody (02-11-2013)
Old 02-11-2013, 12:30 PM
  #1204
03 CLS-6
1foxbody's Avatar
After double checking the jets after at the time it was only about a 110 shot give or take a little. I was using the wrong chart. They weren't true slicks but they were very close. They were a dot approved tire mounted on oem 02 cl-p wheels. I think one of my main problems at the time was my oem clutch it sucked horribly lol. Regardless you are very close and those are some good et's you cut n/a.
Old 02-11-2013, 05:34 PM
  #1205
Trying to get quicker everyday.
I think these tires will do better 60fts as weather gets warmer but I really need something stickier so I can leave with all it's got.
I am getting better 60fts because I'm getting better at babying it off the line
Some bs today,
I've been looking up and down for days for a light weight battery and just took a bad loss on ebay for a lithuim pro c925.
I put my opening bid 225 with max bid 400 and somebody won it with a 227.50.
WTF really, Its like a 1200 dollar battery.
Old 02-11-2013, 07:33 PM
  #1206
Atlas.46's Avatar
Some bs today,
$1200 battery!!!! What
Old 02-12-2013, 01:34 PM
  #1207
Since I lost the other battery.
I guess I had to buy a new one.
4.2lb lithium pro c680 on the way.
Soon to be another 17lbs lighter. If it's small enough I will be removing the oem battery tray as well.
Old 02-12-2013, 02:54 PM
  #1208
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,478 Likes on 3,071 Posts
Nice weight
Old 02-12-2013, 03:53 PM
  #1209
Daily
Old 02-12-2013, 11:14 PM
  #1210
All motor
Sonnick's Avatar
Wow! Congrats bro! 1.99 60' is serious on street tires!! 8.32 @84 should be around 12.8-12.9 @106.x! You need to dyno now
richardparker (02-13-2013)
Old 02-13-2013, 10:41 AM
  #1211
Lone Wolf
brian6speed's Avatar
Do you plan on removing the moonroof and associated assembly?
I looked at lithium batteries previously just thought they were to expensive. The prices will go down a lot next few years, plus I replace batteries too often.
How about mounting the battery inside in a battery box or in the trunk? The extra heavy wires might make it not worth it.
Old 02-13-2013, 11:06 PM
  #1212
Not sure about removing the sunroof stuff yet.
How much does all the sun roof stuff weigh ?
I wonder how much would be saved by just replacing the glass with some thing lighter so I could lose weight and still be able to use the sun roof too.
Old 02-14-2013, 02:49 PM
  #1213
Another 3lbs of dead weight off.
Old 02-14-2013, 03:58 PM
  #1214
6mt swapped..smart
AnthraciteTypeS's Avatar
Great times bro, I also may have missed it, but are you still on the stock ecu? Also, how are your intake runners so clean- are you bypassing egr?
Old 02-14-2013, 04:32 PM
  #1215
Stock cls ecu
The runners were out recently so I probally wiped them out.
I do get some oil in the mani but,I have cleaned it out 3-4 times within 5k miles so it stays clean.
I should get a catch can.
Old 02-14-2013, 05:57 PM
  #1216
wham bam thank you ma'am
Rajca's Avatar
sunroof and the sunroof accessories are about 40lbs. but ur taking 40lbs out from the highest point of the car so ur will notice more of a difference.
Old 02-14-2013, 06:37 PM
  #1217
Lone Wolf
Sunroof weighs 40-50 lbs total weight. The glass should be somewhere around 10 lbs. I don't think it is worth just trying to remove the glass. I would say all or nothing.
You can just block off the erg or use a spacer like one Paul makes. Then add a catch can. My tv and intake have been spotless since then.
Old 02-14-2013, 06:43 PM
  #1218
40-50lbs from the top would be a huge gain in performance.
Most likely less weight transfer from a dead stop and definitly better turns.
Old 02-15-2013, 02:09 PM
  #1219
(Mid-Atlantic)
Nice times RP
richardparker (02-16-2013)
Old 02-15-2013, 03:04 PM
  #1220
Lone Wolf
Why did you remove the headlight ballast?
Old 02-15-2013, 05:04 PM
  #1221
2600lb CL
Cocoa's Avatar
When I removed my sunroof and everything with it, it came closer to a total weight of 75-80lbs. I'd have to look up one of my old threads for the exact number. I was actually surprised back then when I weighed it.
Old 02-15-2013, 05:29 PM
  #1222
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
When i removed the moonroof on my prelude everything totaled in at 42lbs if i remember correctly (i then welded in a piece of metal to fill the hole, i did it more for head room with a helmet, which i gained about a inch and a half)
Old 02-16-2013, 07:55 AM
  #1223
Since I swaped to aftermarket hid's I had one still left on a lamp.
I removed one and sealed the hole but the other I never did.
Now the other is removed and sealed.
75-80.
If that thing was 80lbs I would rip it out in a second.
Old 02-21-2013, 12:11 PM
  #1224
Crappy ebay sellers,I can find them that's for sure.
3 days after my battery was to be here. I got a order cancellation for the battery. This is 10 days from order date and seller said the item was on back order.
Payment was refunded .Now I got a 2nd chance to decide if I really want to spend over 5 beans on a battery.
Old 02-21-2013, 03:21 PM
  #1225
(Mid-Atlantic)
Really? I thought it was like 45
Old 02-21-2013, 03:22 PM
  #1226
(Mid-Atlantic)
Damn dude, that blows
Old 02-21-2013, 05:40 PM
  #1227
It was like I was waiting for x mas to come.
I hate waiting for something.
The lithium pros will not be instock till at least the 1st and thats to frig'n long.
Only 2 batterys that I can have to my door before I go the the track that I might be interested in are
11lb braille ,wich I dont even know why I'm considering it.
4.9lb shorai lfx36 wich it's not recomended for cars.
shipping is pretty rough with it having to be overnighted+saturday since I missed todays cut off time.
but I need something.
wich one?
I'm leaning to the shorai because of weight.
Old 02-27-2013, 01:45 PM
  #1228
Decided on the shorai
Started the car right up,so it's got the power.
Need to drive the car for a hour to see how it deals with the alt.
Also have to see how it handles the cars parastic draw over night.
If the battery can't deal with the above it will be a race day battery only.
Old 03-01-2013, 03:09 PM
  #1229
HickamHatch's Avatar
Holy GOLD Batman
Old 03-01-2013, 03:20 PM
  #1230
The battery is holding up so far.
I've been out on 3 30minute drives and don't see any ill charging problems yet.
This morning I went out to try the battery in the cold and it was high 30's and the car started right up.
Great way to lose 25lbs+ over a oem size battery.
I've been considering figuring out a light weight alt and starter.
There has to be something to use that will save some poundage.
Old 03-01-2013, 11:06 PM
  #1231
Rajca's Avatar
y not get light weigh racing seats? factory seats are around 80lbs. u can get racing seat that weight around 20-30lbs x2 thats alot of weight saving right there
Old 03-02-2013, 08:15 AM
  #1232
Oem seats are already gone.
I have one 24lb drivers seat only.
I don't think I've even taken pics of the interior since the strip down because I've been to lazy to clean the residue from the sound deadener.
I will take a couple though when it stops raining.
I need to make a item list of items removed. Their really is not much left to remove
Old 03-02-2013, 10:13 AM
  #1233
No interior
Old 03-02-2013, 10:52 AM
  #1234
Lone Wolf
There is always more to do, just matters how far you take it. Clean up that residue already. If I was you I would put the airbag cover back in the dash for looks reasons.
You can remove those metal brackets for the dash console. A lot of wiring can be removed. Are you driving it without the cross members? Those are structural.
Old 03-02-2013, 04:22 PM
  #1235
Received 1,858 Likes on 1,499 Posts
lol, that's what I was thinking when I observed the picture.
Old 03-02-2013, 05:30 PM
  #1236
I'm just about as far as I'm going to take the weight removal till I get another car.
Besides getting lighter pieces.
I did want to put the airbag cover back on and I ment to ask you about it.
I was nervous messing with it.
I do want to remove all the srs wiring and wiring for the rear amp if possible but I'm not sure how much else of that will be removed.
The car does not see hardly any street time besides back and forth to the track wich is only 5miles away.
So any structual pieces are removed including bumper beams.
Old 03-02-2013, 11:08 PM
  #1237
Rajca's Avatar
fuel cell? since u dont drive it much or far.
Old 03-03-2013, 01:12 AM
  #1238
03 acura cl type s
rush's Avatar
If I where you ill swap the trans to a 6speed and just get the AEM EMS plug & play no need to look all the nesasry 6speed parts (lighter trans +tune= more power) just IMO
Old 03-03-2013, 01:11 PM
  #1239
Could not get no traction today being 44 degrees.
But,I did trap 88.2 mph in the 1/8.
Can't wait for a warm day I will run low 8.2 possibly even crack 8.1's with a few more lbs off.
Old 03-04-2013, 12:25 PM
  #1240
Took out this stuff today.
Another 7lbs lighter.
Quick Reply: Started on some in home porting
