Shock Sensor Help
Shock Sensor Help
Might belong in the AV section , but I figured I'd get more help. I had a full set of printed instructions, from 2 different people, & I still couldn't do it. I did get the ground. The yellow wire with silver dots confused me. I saw one of these wires, but it went right into the top left corner of the fuse panel. I saw it when I opened the fuse door. Didn't know if it was the correct wire. If it was I didn't see why I had to tap it in the wire bundle. For power, I saw the U box, but in my attempt to plug the wire in, I guess I bet the prong, & now it's bent inside the gray panel. I tried to get the front panel off, by taking the 2 screws out, but it still wouldn't budge. how do I get that off. Also if I can't use the U box for power, can I use one of the others I saw.
Originally posted by JasonT
I think it is hood.
I think it is hood.
Jason,
Check for metal latch that holds the control box to the dash. Look for it at places indicated in the below picture. It's been a while so I dont remember exactly where it is.
I'll see. Now in the pic the yellow circle is where that yellow wire is by the fuse box. Can I just tap it there? & if I did bend the U prong too much, & can't use it, can I use one of the other ones, or just tap another power source.
Just connect the red wire to any constanst voltage source (battery).
