RL Cams 2006
Ok, Tom I stopped by the shop on the way home and measured them all like this
So they stand on the following order as seen above with multiple pics
CL-S (FR) ___15 11/16"
RL (FR)_____15 1/5"
RL(RR)_____15 5/16"
CL-S (RR)___15 7/16"
So, as you can see the front (FR) CL-S cam is much longer than '06 RL (FR). That is the issue since it's going to be too close to TDC sensor.
Let me know what are the dimensions on '05 both cams. But most important is FR cam.
RL (FR)_____15 1/5"
RL(RR)_____15 5/16"
And just for heck of it if you want to know the complete length including end caps. So they measured like this.
CL-S (FR)____15 7/8"
RL (FR)______15 11/16"
RL (RR)______15 1/2"
CL-S (RR)______15 11/16"
Originally Posted by CleanCL
02av6 or anyone else... is the TDC Sensor placed different in the RL? maybe this is how it clears. i'm just trying to figure out what acura did.
Edit: Need to correct the measurements on RL (FR)
RL (FR)_____15 1/2"
RL(RR)_____15 5/16"
So, as you can see the front (FR) '06 RL cam is shorter than CL-S (FR). That is the issue since it's going to be too close to TDC sensor.
RL (FR)_____15 1/2"
RL(RR)_____15 5/16"
i cant imagine 05 cams being different than 06, this doesnt seem cost effective to acura at all. but then again, acura/honda has done weirder things. thinking again, the price difference must make up for something. maybe they were redesigned once they caught wind of people swapping them into our heads.. haha.
ps. 02av6, if the 05s are butter, you will see some nice gains.
upon some more thought, at the time i ordered all my parts, i told my parts guy exactly what i was doing, he works for acura parts but he has dealt with the 3.5 swaps before, and the fact that i ordered the cams didnt phase him at all, he would have mentioned something if it bothered him, he is extremely helpful like that. but i remember all the parts he ordered he specifically ordered from the 05 year.
Here's the long awaited answer.
Front RL cam from end to end is 15 3/4" 15 13/16"
Front RL cam from end to ? is 15 1/2"
Rear RL cam end to end is 15 9/16"
Rear RL cam end to ? 15 5/16"
both cam side by side, front on top, rear on bottom. If your wondering why it says 16'', it's because I didn't use the end of the tape measure, started at 1''.
measurement of front cam, on top,
another view.
measurement of rear cam.
What does this mean? Means there is some legwork to be done. If you end up using the rl tdc sensor, which I believe there is only one, the cl has tdc1 and tdc2, it won't work with your ecu. You'd have to go stand alone and be creative on assembly.
another view.
Originally Posted by typeR
yo thin not sure im following your above mentioned measurements? does it go '05 RL then '06?
length without right side end-cap
CL-S (FR) _____15 11/16"
'06 RL (FR)_____15 1/2"
'05 RL (FR)_____15 1/2"
'06 RL(RR)_____15 5/16"
'05 RL(RR)_____15 5/16"
complete length end-to-end
CL-S (FR)_______15 7/8"
'06 RL (FR)______15 11/16"
'05 RL (FR)______15 13/16"
'06 RL (RR)______15 1/2"
'05 RL (RR)______15 9/16"
CL-S (RR)_______15 11/16"
Hmm, doesn't look good since both '05 and '06 are the same before end-cap.
I might be off 1/16" or so when measured complete length-to-length on '06 but it doesn't matter. What matters is that before end-cap both cams are identical:
Well, we still getting the '05 cam so we'll check again, but it doesn't look good.
As far as TDC sensor correct, RL has one while CL-S two. Regardless, I wouldn't use or anyone else for that matter that sensor.
Ok, so now we know both '05-06 RL cams are identical as I suspected despite listed as different part #.
Theory:
Now, since front CL-S cam is just 3/16" longer than RL it may sound not much.
However, two CL-S 5AT TDC sensors (attached to a front cam plate) sticking out 3/8" toward the camshaft. So, with RL unit installed it might affect a clearance issue to the sensors because it might sit too close. This can also cause the cam gear/timing belt misalignment which has to be checked as well.
What does it mean? Well, the sensors might get hit with rotation upon firing up the car and it's a no, no.
Practice:
I have asked my mechanic to do a test fitment to be 100% certain if this swap requires a lot of changes to make the front cam work. This is going to be a last attempt and I'll post the results asap.
Theory:
Practice:
Originally Posted by av6ent
Holy shit, so '05/06 are the same, why da hell Honda made different part #
Good luck with fitment, maybe everything works out.
My apologies for sharing inaccurate information. That was not my intent. I too am a victim as the shop where my motor was at said they would work and were a direct fit. I wasn't told that they were shorter.
Originally Posted by jgscott
Sorry for asking such a dumb question but.... is it goiing to work ? Or it going to require a Modification ?
what about a custom cam? I don't see a company picking up the design for a marketable product (this point was from eairlier in this thread), however with the knoledge here, I'm sure we could choose our best cam design, then get a shop to make ten or twenty of them..
This article discusses a company that makes custom cam shafts..... http://www.circletrack.com/techartic...2_cams_custom/
the company that they talk about is Jones Racing, I'm not sure what their website is, there is a www.jonesracing.com but I'm not sure if that is the specific company.
Serge and everyone-
Maybe he had some other idea as to using different sensors with a stand alone. If I had known there was a difference in length, I would have said so. I'm not done with it yet as I think there is the possibility that it may work.
Well, consider I've got another valve adjustment and new plug installation
. And I hope people here appreciate my time, my money and attached pics.
Originally Posted by implicit
Hey man...I just want to say for myself that its very appreciated. And I'm sure a lot of us here were hoping these were going to fit. Props for being brave enough to try it and props for providing all of the valuable info.
DITTO x 10'000
FINAL VERDICT
Unfortunately, not going to work (at least on 5AT) and here is why.
Front RL cam installed into CL-S cyl. head
And here is a front plate with attached TDC sensors and RL camshaft without front cam gear
Another angle with TDC sensors and RL camshaft before cam gear installed.
Finally here is a cam gear installed. See how camshaft not lined up with cam gear by being simply short? And unfortunately there is nothing we can do to make it even you don't want to run it like that since timing belt will be off along with important clearance to TDC sensors.
And to confuse you even more, when I said above "not going to work (at least on 5AT)" Honda list the different part # for CL-S 6MT and 5AT for the following parts: Front CYL. HEADS/ CAM GEAR/ PLATE along with different TDC sensors.
Doubt if there is a true difference except TDC sensors since and I suspect it was made to distinguish 6MT from 5AT parts.
Tom, if you still have them installed on the other head. Check if FRONT camshaft lined up with a FRONT cam gear (see the above pic) that way we'll know a true difference between 6MT.
What about a custom made cam? we have all the specs for it, and we could get it made to exact legnth
It is possible... and we could get a group rate from someone that makes custom cams..
Any ideas?
Any ideas?
thank you for the leg work. hopefully we can return our cams. but before i do, i just want to throw this out there, and maybe someone has a logical answer...
when i look up the part #s for a 2001 CL Type S 5AT - i get 4 part #s for the cams, but if i look up a 2003 CL Type S 5AT - i get only 2 part #s. why are there 4 listed for the 01s?
while we're at it, will the 05 RL head bolt up to a j32a2 block? we all know the head and cams produce more power, the only issue i see is changing the exhaust. e-shifts 'headers' should work. thanks to typeR for inspirations. maybe someone can look into this.
might the RL's cam gear have this issue resolved?
i was thinking that, and started look at the cam gear part #s, the gears are only about $10 a piece, worth it to see. but you can see from o2av6's pictures that the sensors clearly come really close, the RL cam gear would need to be very deep inside so the sensors can rest inside. but i haven't seen the RL head that close, so i don't know the position of the sensor.
Originally Posted by Louie11
Great work as usual!!!!
You really have Benson and the boys working over time aren't you.
Any ideas?
Any ideas?
And to lower the price, I'm sure the demand should exceed 25 sets or so. But most important, nobody going to purchase even a single set unless someone tries it first and presents before/after SAE Dyno
when i look up the part #s for a 2001 CL Type S 5AT - i get 4 part #s for the cams, but if i look up a 2003 CL Type S 5AT - i get only 2 part #s. why are there 4 listed for the 01s? .
