Review: UR Crank Pulley
B A N N E D
So I went ahead and finally ordered my Unorthodox Racing underdrive crank pulley for my '03 CL-6. I already have intake/exhaust/headers and I went ahead and finally brought the UR crank pulley for the car. I absolutely love this mod, and I might even think it's the best mod for the buck, in terms of performance. The car feels MUCH much much stronger up top. From about 3K RPM's or more it really has a bit more of power, revs up extremely fast. Before 3K RPM's I notice a little more low-end torque, but nothing too crazy.
I haven't really had a chance yet to test the gas mileage difference, but I'll stay updated if I notice anything.
And I absolutely love how smooth the power band feels, the car feels retarded fast now up top - I can't even imagine how it's going to feel with the SC.
The only mods I really have next coming up are the satin silver custom steering wheel and the SC!
140,000 miles young
my question is this: why doesn't acura equip the Cl with the UR underdrive-sized pulley from the factory? I understand the aluminum also contributes, and that this is more expensive, but why is the diameter larger from the factory?
What is hurt/less reliable with the UR underdrive pulley?
Well...it's kinda fast...
Other than the weight savings, the benefit (in theory) is less parasitic drag...less weight + slightly underdriving your accessories = more power to the wheels. I personally love mine, the 2nd best performance upgrade next to headers IMO.
140,000 miles young
Oh I get the benefits and they are sweet. My question is what is the danger of installing it? Why doesn't acura have it smaller from the factory if it's such a simply power gain solution? What are the potential damages/negative side effects of having an underdrive pulley?
Originally Posted by BigLizard
when i had my acura i had the same thing happen, the RPMs jumped up crazy fast.
Uses turn signals in my
Originally Posted by SPoolinspOON
so.... the underdrive crank is the one to get? Is it that much noticable differance then then stock sized UR pulley?
If you have an audio system over 600rms watts or you have a supercharger, the stock sized would be recommended. You can reuse the stock belts if they are good condition.
So in the end its what suits you best.
B A N N E D
And since I plan on doing the SC I used the UR stock sized pulley.
Only CL in town!
you can get the belts for the underdrive for $40 from excellerate. If your not wantingboost or a big system then the underdrive if definately the way to go. Thats the route i went
Moderator Alumnus
Originally Posted by turbo_911
so you sold your green cl-p? what else did i miss? lol
140,000 miles young
Can someone answer this pleasssse? Does it put any stress on the driveline/engine? Are the gains more from the weight savings of the aluminum (expensive) vs. the smaller size (cheaper)?
No negative impact on our engines since they are internally balanced. Why didn't they come like this from the factory? Simple, very few cars (even exotics) come from the factory with parts that are fully optimized to achieve maximum performance. Some parts (i.e. crank pulleys, intake systems) are created to achieve a balance of performance and function, but not max performance at the expense of comfort, reliability, etc. (aftermarket intakes are noisier, underdrive pulleys don't charge the electrical systems as efficiently, performance exhausts are louder...you get the idea). That's why there's a market for aftermarket performance parts.
And yes, the majority of the gains are a result of the lighter weight, not the underdriving, hence the stock size UR pulleys also create almost equal gains.
'03 ABP YA4-S 6MT
if you get the stock size pulley, you get say, ~9 hp vs. ~10 for the underdrive.
so, if you want to make it up you can buy the 3 pulley set and make up for the underdrive (since those give ~1hp each)
140,000 miles young
2clean - thank you. i get the whole aftermarket louder/harsher reason why things aren't made the best stock (love the noise my intake makes, can't wait for the harsher-riding drop im about to get). I just wanted to understand the reasoning behind not putting the higher-performance pulley on from the factory, which the last part of your post answered in stating that the lightness is the biggest factor in performance gains - thus the more expensive aluminum.
Thanks for the clarification - non underdrive UR pulley on order.
Former Sponsor
Unorthodox Racing has a great FAQ on their products if you go to www.unorthodoxracing.com and then info then FAQ then choose the pulley category.
Got DEP???
I saw a DEP 01 for sale down the road with the spoiler, if I had a license I might have looked. HAHA
No need for an auto though
AcuredCLS
when you do the pulley kit does UR give you the belt with kit....and how does ur alternator run do you need like a high output one?...or if u wanna change from stock to high output is their a problem?
Former Sponsor
140,000 miles young
Unorthodox Racing states you will be fine with up to 600watts RMS using the underdrive...but I'd probably go with stock size since you are pushing that limit n u never know where your gonna go from here.
'03 ABP YA4-S 6MT
you don't 'need' anything when you're installing headers... except new bolts and gaskets maybe.. but they're in totally different parts of the engine, so it's not like you're saving any time by doing it together..
probably better to do it separately so you can gauge yourself how powerful each mod was
Chapter Leader (NY/NJ)
oh ok cool, thanks good to have know this.
So how much is the underdrive pulley along with the other belts you need with it etc? Member here is saying feels a lot of power at the high end, where I read it helps at low end. Which was is the answer? Including installation how much should I be looking at for this mod?
Former Sponsor
Pricing is here:
https://acurazine.com/forums/sponsored-sales-group-buys-10/unorthodox-racing-special-pricing-event-acura-cl-tl-rl-mdx-tsx-301566/
We have the belts for $40 but you can also source them locally.
Thanks excelerate..one last thing, I was searchign through all the posts, I heard mention of 14hp for the CL-S...is there any dyno results available that I could see that show hp and torque gain for a 2003 3.2 Cl Type S?
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
