Reverse Lights NOT Working
Old Jul 19, 2013 | 02:16 PM
CL REASON's Avatar
I have an 03 CLS6 and i just noticed the reverse lights don't work!! i have check the fuses and the bulbs and both are fine. the mirror thats supposed to fold down when in reverse does work either. Has anyone had this problem and found the way to fix it
Thanks CL REASON.
Old Jul 19, 2013 | 05:33 PM
Karanx7's Avatar
Unregistered Member
Because of the mirror and reverse not working, you can assume the car isn't getting the signal for the reverse gear.
Are you 100% sure the reverse relay isn't faulty? Check the voltage to be absolutely sure.
Old Jul 22, 2013 | 09:33 AM
CL REASON's Avatar
reverse relay? dont know where that is... i have put a continuity tester to the reverse light harness is before it goes into the bulb and nothing
Old Jul 22, 2013 | 12:47 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Are your reverse lights coming on in any gear or parked?
Could be the netrual safety switch/range switch. does the car start only in park and neutral?
Old Jul 22, 2013 | 10:28 PM
CL REASON's Avatar
Car is a 6 spd and no they do not light up at all.
Old Jul 22, 2013 | 10:45 PM
mordor110's Avatar
Nick
Check the switch on the gearbox? Haven't had it happen on my CL but many years ago the reverse switch went bad on my Legend 5 speed. On that there was one swicth for reverse and another for neutral. (Neutral signal went to ECU)
I seem to remember when the fuse popped for the reverse lights the instrument cluster lights dropped out too.
Old Jul 23, 2013 | 09:02 AM
CL REASON's Avatar
Where exactly is the switch on the gear box on the cl? How do i check it?
Old Jul 23, 2013 | 09:11 AM
CL REASON's Avatar
5 28700-PWL-013 SWITCH ASSY., BACK LIGHT (BLACK) (U-SHIN) is the the part i need
Old Jul 23, 2013 | 09:46 AM
harvthesecond's Avatar
Most honda parts sites have pictures. #5 in this one.
Old Jul 23, 2013 | 12:03 PM
CL REASON's Avatar
Ok I have seen the diagram but can anyone take a pic of the actual switch on the car
Old Jul 24, 2013 | 01:32 AM
mordor110's Avatar
Nick
Looks pretty easy to see from above in that parts diagram. Should be under the intake tube from air filter to throttle body. My suggestion was just that, an idea of something to check. Check it for open or closed when car is in reverse etc. May not be bad? You need to check it first.
Old Jul 24, 2013 | 12:22 PM
CL REASON's Avatar
the diagram above is of an accord...
the diagram of the cl transmisson its #15
http://cdn.revolutionparts.com/ill2....593&make=acura
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
Mcj270
Aug 31, 2015 04:45 PM
