Rear mounted turbo?
Old Mar 16, 2011 | 10:45 AM
dbramaged's Avatar
Rear mounted turbo?
Has anyone tried or seen a rear mounted turbo set up on a CL/TL?
Old Mar 16, 2011 | 11:13 AM
TheWeez's Avatar
I Wanna Beer
The member rear turbo cls6 has done it.
https://acurazine.com/forums/2g-cl-2001-2003-50/turbo-cls6-shout-out-azine-799600/
You will see plenty of people going on and on and bitching about how the turbo could get hit with rocks and stuff yet there are plenty of people out there with them on countless cars that have no issues with it.
Old Mar 16, 2011 | 11:24 AM
brian6speed's Avatar
Lone Wolf
https://acurazine.com/forums/showthread.php?t=799600
Looks like his isn't rear mounted according to his post "I originally was going to go with the rear turbo setup but my mechanic ran the rear turbo setup and said he made great power but the problems were so bad that he took the setup off. So I decided to go with a top mount. As for injectors, I didnt know how reliable the rdx setup was so I went with lucas 440cc injectors. Aeromotive fpr and obx fuel injectors. Which leads me to my next question....Im a little unsure of how to setup the fuel rails with the fpr. Could anyone give me a brief explanation of how that setup would go?"
Old Mar 16, 2011 | 11:25 AM
TheWeez's Avatar
I Wanna Beer
OK, then no one has a read mounted setup.
/thread
Old Mar 16, 2011 | 12:05 PM
dbramaged's Avatar
You can always have a shield made to protect the turbo. I'm more curious about running the oil lines, vacuum lines, and where the filter would be mounted. I know every winter it would have to be removed to keep it from getting covered in snow & salt unless I buy another car. I figure if I ran e-manage at only 5-6psi, it would be a fairly reliable setup.
Old Mar 16, 2011 | 12:59 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
I have thought about it before.
A Twin Turbo setup like they have for the new vettes.
Their plenty of room under ours if you take out the mufflers
Old Mar 16, 2011 | 02:25 PM
dbramaged's Avatar
I'd most likely run a single turbo with a single sided exhaust though.
Old Mar 16, 2011 | 02:27 PM
Aman's Avatar
Your Friendly Canadian
I can't imagine a rear mounted turbo would be particularly efficient compared to one in the engine bay.
Old Mar 16, 2011 | 03:02 PM
dbramaged's Avatar
I was talking with a guy last night about this as he has duals on his G8. He said that it's actually easier to mount and work on as it's more open and accessible. He had issues finding the oil feed/return lines and vacuum lines. He previously had a low mounted TT setup and said there isn't a difference in efficiency or lag times.
Old Mar 16, 2011 | 04:45 PM
Lone Wolf
I would think installing in engine bay would be easier and more protected. The cl has plenty room left in the bay.
Old Mar 16, 2011 | 04:52 PM
Jacobpockros's Avatar
Actually, factor in weight distribution. Rear turbo setup=more weight in the back plus all that extra piping, then you don't even need to worry about the pain in the ass battery relocation.
Old Mar 17, 2011 | 07:11 AM
dbramaged's Avatar
After relocating the battery, having a custom manifold made, custom downpipe and then piecing together a FMIC piping system. I've turboed a few Hondas before and it's not easier from what I've read about the rear mounts. And overall, this rear mount could be cheaper too.
Old Mar 17, 2011 | 09:33 AM
dbramaged's Avatar
EDIT: I just realized I sketched it up backwards... Basically everything would be reversed with the intake on the driver's side and the exhaust on the passenger side.
This is what I'm thinking:
Old Mar 17, 2011 | 10:06 AM
What are you going to do to stop heat soak between pipes ?Charge and exhaust pipe are right next to eack other.
Old Mar 17, 2011 | 10:09 AM
dbramaged's Avatar
FMIC & exhaust wrap will help a little.
Old Mar 17, 2011 | 10:20 AM
phee's Avatar
I got the Shifts
What about rust?
Old Mar 17, 2011 | 10:25 AM
dbramaged's Avatar
Originally Posted by phee
What about rust?
Stainless Steel piping and shielded components. My factory exhaust on my '02 has almost no rust on it now and I live in the snow belt. (Nebraska) lol
Old Mar 17, 2011 | 01:14 PM
dbramaged's Avatar
So the sketch I did won't work either due to the sway bar after looking at some pictures of the under carriage. Looks like I would have 1 of the following 3 setups:
Driver's side exhaust:
Passenger Exhaust & Intake:
Passenger Exhaust, Driver Side Intake:
KB1_EJ6
Nov 13, 2016 09:51 PM
wilztlxs
Dec 1, 2015 09:16 AM
Sep 14, 2015 10:09 PM
2015TLX
Sep 11, 2015 02:56 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
