Rajca's Project CL-S6 Car
#601
B A N N E D
and as said befor it will be the programming for the skewing of the o2 that will be the problem to keep the computer happy,
cause in a simple world you could just program/map in the flow of the valve at a certian opening with how much to skew the o2,
but in a more complex world, you gotta make multiples programs/maps/correction-factures
cause you gotta take in account the engine's rpm, the current load (map sensor, what gear, but also uphill or downhill, let alone the weight of the car), the driver demand (throttle opening),
also depending on how sophisicated the factory ecu is you might need take into these factures too: the exact temp of the engine, temp of the o2 sensor(yes some cars actually report that back, but not ours), current altitude (actually the barometric pressure)
so not going to be an easy job while still using the factory ecu
#604
already have the walbro 225lph fuel pump. had it on my car since i did teh nitrous setup.
i am now looking for a fuel pressure regulator. i want to get rid of the whole stock fuel system under the hood. so any help as to what is a good fpr and where to get fuel lines would be great
#605
B A N N E D
#608
Whats up with RDX owners?
Hmmmm. Those fuel rails are enticing...
#616
Why did you enlarge the holes for the RDX injectors?
#618
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Fries and Civic, this is your one and only warning, stop hijacking and postwhoring in this thread. Posting 1 word posts is ridiculous and childish and clutters up threads, next one to do it gets a week off.
#620
I Drive Like A Dick 8≈
#629
And most likely in the 1/4 too if your running on the streets.
#631
I would not bet any money on that race unless your running slicks in the front. Your car will obviously have the power and torque to beat him, but AWD evo's from a dig are poison, and your gonna have a hard time hooking up on stock tires with all that power
Im sure you would rape him on a roll reguardless.
#635
all depends on what u do to the car and what u build it for. ill post results when this happens, but not until its nice out bc i had a close experience on cold asphalt, and it was damp in one spot. cam inches away from hitting a barrier on the highway at 130+. that what i saw then a few sec later i started doing a 180 and sliding sideways looking at the wall
#638
Ive had one too many close calls that now keep me from going much higher then 110 (still dangerous, I know). Its not worth putting other peoples lives in jeopardy.
